pdf
Electronics All-in-One For Dummies, 2nd Edition
  • 1星
  • 日期: 2020-10-08
  • 大小: 24.18MB
  • 所需积分:0分
  • 下载次数:2
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 电子
最早发现的基本粒子。带负电,电量为1.602189×10-19库仑,是电量的最小单元。质量为9.10953×10-28克。 常用符号e表示。1897年由英国物理学家约瑟夫·约翰·汤姆生在研究阴极射线时发现。一切原子都由一个带正电的原子核和围绕它运动的若干电子组成。
A comprehensive collection of 8 books in 1 offering electronics guidance that can\'t be found anywhere else!If you know a breadboard from a breadbox but want to take your hobby electronics skills to the next level, this is the only reference you need. Electronics All-in-One For Dummies has done the legwork for you — offering everything you need to enhance your experience as an electronics enthusiast in one convenient place.
Written by electronics guru and veteran For Dummies author Doug Lowe, this down-to-earth guide makes it easy to grasp such important topics as circuits, schematics, voltage, and safety concerns. Plus, it helps you have tons of fun getting your hands dirty working with the Raspberry Pi, creating special effects, making your own entertainment electronics, repairing existing electronics, learning to solder safely, and so much more.
Create your own schematics and breadboards
Become a circuit-building expert
Tackle analog, digital, and car electronics
Debunk and grasp confusing electronics concepts
If you\'re obsessed with all things electronics, look no further! This comprehensive guide is packed with all the electronics goodies you need to add that extra spark to your game!
更多简介内容
推荐帖子
Altium如何设置Solid Region(实心区域)的最小面积
在绘制过程中双击导致编辑区域内存在一些极小的实心区域,有的实心区域自动赋予了网络,走线时会自动避让才发现类似的细线。 并且在最后的DRC中,低版本的AD会报 Broken-Net Constraint,即使该极小的实心区域在敷铜范围内。 由于是重叠的闭合细线,很难肉眼观察到该实心区域,并且很难选中删除。   所以想请教下有无设置或者是规则可以约束这个实心区域的最小面积,规避
大小家伙好 PCB设计
【GD32450I-EVAL】+ 05FreeRTOS移植与任务创建
本帖最后由 DDZZ669 于 2020-9-26 15:34 编辑         FreeRTOS是一个迷你的实时操作系统内核。作为一个轻量级的操作系统,功能包括:任务管理、时间管理、信号量、消息队列、内存管理、记录功能、软件定时器、协程等,可基本满足较小系统的需要。   1 FreeRTOS基本结构         FreeRTOS系统简单小巧、文件数量少、通
DDZZ669 国产芯片交流
LM2596使用经验
本帖最后由 qwqwqw2088 于 2020-9-25 11:09 编辑      LM2596系列是TI公司生产的3A电流输出降压开关型集成稳压芯片,它内含固定频率振荡器(150KHZ)和基准稳压器(1.23v),并具有完善的保护电路、电 流限制、热关断电路等。利用该器件只需极少的外围器件便可构成高效稳压电路。提供的有:3.3V、5V、12V及可调(ADJ)等多个电压档次产品。就以
qwqwqw2088 模拟与混合信号
Linux应用开发手册基于ARM AM335x
开发案例说明 本文档涉及的开发案例位于产品资料“4-软件资料\Demo\tl-linux-application\”路径下的base-demos和python-demos目录。 base-demos目录存放Linux常用开发案例,案例bin目录存放可执行文件,案例src目录存放源码。python-demos目录存放Python开发案例,案例脚本文件无需编译,可直接运行。 如需重新
Tronlong小分队 Linux与安卓
CC2xxx的输出/输入阻抗值具体是多少?
本帖最后由 Jacktang 于 2020-10-4 15:55 编辑     对于单端输出/输入,我们可以视为 50 Ohm。对于双端差分端口,如 CC253x 和 CC254x, 差分阻抗为非标准值。TI推荐复制参考设计而不是告知具体阻抗值有以下考虑。     首先,CC253x, CC254x 等差分端口芯片的射频输出/输入阻抗不是标准的 50 Ohm 或 100 Ohm。
Jacktang 无线连接
基于SDI7768的高精度计量插座方案
一、计量插座的开发背景 随着社会进步人们生活中使用的电器越来越多,各种大功率电器成了用电大户,但是你能知道空调开一晚上用多少电么?电饭锅烧一锅饭用多少电么?各个电器厂家标的电器功率、能耗等级有没有虚标?因此设计一款能实时显示用电器功率、用电量的计量插座方案很有现实意义。本节计量插座方案能让用户实时监控家里用电器的用电情况 。本高精度计量插座方案选用SDI7768高精度电能计量芯片开发,能实现
solidic stm32/stm8
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
