pdf
A precision variable-supply CMOS comparator
  • 1星
  • 日期: 2020-12-08
  • 大小: 1.15MB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: CMOS比较器
CMOS比较器
Several  new  techniques  are  presented  for  the  design  of  precision  CMOS  voltage  comparator  circuits  which  operate  over  a  wide  range  of  supply  voltages.  Since  most  monolithic  A/D  converter  systems  contain  an  on-chip  voltage  reference,  techniques  have  been  developed  to  replicate  the  reference  voltage  in  order  to  provide  stable  supply-independent  DC  bias  voltages,  and  controlled  internal  voltage  swings  for  the  comparator.  These  techniques  are  necessary  in  order  to  eliminate  harmful  bootstrapping  effects  which  can  potentially  occur  in  all  AC  coupled  MOS  analog  circuits.  An  actively  controlled  biasing  scheme  has  been  developed  to  allow  for  differentially  autozeroing  the  comparator  for  applications  in  differential  A/D  converter  systems.  A  general  approach  for  selecting  the  gain  in  AC-coupled  gain  stages  is  also  presented.  The  comparator  circuit  has  been  implemented  in  a  standard  metal-gate  CMOS  process.  The  measured  comparator  resolution  is  less  than  1  mV,  and  the  allowable  supply  voltages  range  from  3.5  to  10  V.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
