pdf
An Analysis of Flicker Noise Rejection in Low-Powerand Low-Voltage CMOS Mixers
  • 1星
  • 日期: 2020-12-09
  • 大小: 206.84KB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 噪声抑制
噪声抑制
CMOS混频器
噪声抑制
flickernoise
噪声抑制
The  sensitivity  of  RF  CMOS  receivers  using  a  directconversion  or  a  low-IF  architecture  is  strongly  affected  by  flickernoise.  This  paper  gives  theoretical  guidelines  to  predict  the  flickernoise  in  Gilbert-cell  mixers.  The  conversion  gain,  the  equivalentinput  and  output  noise,  and  the  effect  of  the  pole  at  the  single  in-ternal  RF  node  are  discussed.  For  the  first  time,  results  which  arevalid  in  all  modes  of  operation  are  given.  Such  complete  results  arerequired  for  some  ultra  low-power  and  low-voltage  applications,since  the  transistors  might  be  operated  in  moderate  or  even  weakinversion  region.  The  theoretical  gains  are  found  to  remain  within  a2-dB  margin  with  respect  to  the  measurements  of  a  UHF  downcon-verter  built  in  a  0.5μm  process,  for  a  large  range  of  bias  conditionsand  local  oscillator  swing.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
