pdf
SPICE Models for Flicker Noise in n-MOSFETs from Subthreshold to...
  • 1星
  • 日期: 2020-12-15
  • 大小: 317.2KB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: HSPICE
HSPICE
PSPICE
PSPICE是由SPICE发展而来的用于微机系列的通用电路分析程序。于1972年由美国加州大学伯克利分校的计算机辅助设计小组利用FORTRAN语言开发而成,主要用于大规模集成电路的计算机辅助设计。
输入参考噪声
n-MOSFET
标题:SPICE  models  for  flicker  noise  in  n-MOSFETs  from  subthreshold  to  strong  inversion
作者:Dingming  Xie,  Mengzhang  Cheng,  Leonard  Forbes
摘要:The  two  main  sources  of  low-frequency  flicker  noise  are  mobility  fluctuations  and  number  fluctuations.  Our  experiments  on  NMOS  noise  measurements  were  done  from  subthreshold  to  saturation  region  of  operation  for  both  long-channel  (5  μm)  and  short-channel  (as  small  as  0.6  μm)  NMOS  transistors.  The  results  suggest  that  for  both  types  that  in  the  saturation  region,  the  flicker  noise  is  due  to  the  surface  state  effect  and  the  noise  equations,  NLEV=2  and  3,  in  SPICE,  HSPICE,  and  PSPICE  are  most  appropriate.  For  short-channel  devices,  due  to  the  effects  of  velocity  saturation  and  the  resulting  nonlinear  transconductance  (gm)  variation  with  gate  bias  voltage,  the  input-referred  voltage  noise  increases  as  the  gate-source  voltage  increases  instead  of  staying  constant  as  it  does  for  long-channel  devices.  In  the  subthreshold  region,  the  input-referred  voltage  noise  decreases  drastically  as  the  gate-source  voltage  increases  for  both  long-channel  and  short-channel  NMOS  devices.  Simulations  have  been  done  using  PSPICE  and  HSPICE,  with  noise  level  (NLEV)=3  and  device  model  level  3  and  BSIM  3.2  and  3.3.  The  results  from  PSPICE  version  8.0  level  7  (BSIM  3.3)  and  SPICE  level  3  compare  favorably  with  the  measured  noise  phenomena  for  the  short-channel  and  long-channel  NMOS  devices,  respectively
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
