标题:A 21.8−27.5GHz PLL in 32nm SOI Using Gm Linearization to Achieve −130dBc/Hz Phase Noise at 10MHz Offset from a 22GHz Carrier
作者:Bodhisatwa Sadhu, Mark A. Ferriss, Jean-Olivier Plouchart, Arun S. Natarajan, Alexander V. Rylyakov, Alberto Valdes-Garcia, Benjamin D. Parker, Scott Reynolds, Aydin Babakhani, Soner Yaldiz, Larry Pileggi, Ramesh Harjani, Jose Tierno, Daniel Friedman
摘要:This paper describes a new approach to low phase noise LC VCO design based on transconductance linearization of the active devices. A prototype 25GHz VCO based on this approach is integrated in a dual loop PLL and achieves superior performance compared to the state of the art. The design is implemented in the 32nm SOI deep sub-micron CMOS technology and achieves a phase noise of -130dBc/Hz at 10MHz offset from a 22GHz carrier. Additionally, the paper introduces a new layout approach for switched capacitor arrays that enables a wide tuning range of 23%. More than 500 measurements across PVT variations validate the proposed PLL design: phase noise variation across 46 dies for 3 different frequencies is σ <; 0.6dB, across supply variation over 0.7-1.5V is 2dB and across 80°C temperature variation is 2dB. At the 25GHz center frequency, the VCO FOMT is 188dBc/Hz.
推荐帖子
精选文集
热门活动
活动回顾
datasheet推荐 换一换
评论
