pdf
Fuzzy Based Optimized Routing Protocol for Wireless Sensor Networks
  • 1星
  • 日期: 2020-12-16
  • 大小: 301.06KB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 无线传感器
  无线传感器的组成模块封装在一个外壳内,在工作时它将由电池或振动发电机提供电源,构成无线传感器网络节点,由随机分布的集成有传感器、数据处理单元和通信模块的微型节点,通过自组织的方式构成网络。它可以采集设备的数字信号通过无线传感器网络传输到监控中心的无线网关,直接送入计算机,进行分析处理。
作者:P.  Manjunatha,  A.K.  Verma,  A.  Srividya
摘选:Wireless  sensor  networks  are  used  in  military,  health  monitoring,  tracking  and  security  applications.  These  critical  applications  require  reliable  and  fault  tolerant  operation  of  the  network.  This  paper  proposes  a  novel  reliable  routing  protocol  for  wireless  sensor  networks  (WSN)  to  extend  the  network  lifetime  using  fuzzy  inference  system  (FIS).  Due  to  limitation  in  communication  range,  sensor  nodes  transmit  their  sensed  data  through  multiple  hops.  Each  sensor  node  acts  as  a  routing  element  for  other  sensor  nodes  for  transmitting  data.The  purpose  of  this  work  is  to  extend  the  network  lifetime  using  FIS.  Each  sensor  node  selects  the  optimized  path  for  forwarding  packets  to  the  base  station  based  on  routing  metrics.  Simulation  results  shows  that  proposed  algorithm  can  achieve  higher  network  lifetime  by  comparison  to  other  routing  protocols.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
