pdf
Low Power Wireless Buoy Platform for Environmental Monitoring
  • 1星
  • 日期: 2020-12-16
  • 大小: 1.03MB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 无线通信浮标
无线通信浮标
环境监测
环境监测
作者:Arne  Sieber,  Juergen  Markert,  Christian  Woegerer,  Michele  Cocco,  Matthias  F.  Wagner
摘要:A  novel  sensor  buoy  platform  was  developed  for  detailed  environmental  monitoring  of  coastal  areas.  Using  many  buoys  in  a  mesh  network  on  low  power  ZigBee  basis  allows  dramatic  reduction  of  the  overall  power  consumption,  enabling  an  autonomous  operation  on  a  single  battery  set  over  3y.  Each  buoy  acts  as  sensor  node  but  also  as  router  forwarding  messages  from  neighbor  buoys  to  a  centralized  server.  Thus  special  attention  had  to  be  directed  to  network  synchronization  and  the  handling  of  processor  sleep  states.  One  –wire  temperature  sensors  were  used  for  temperate  profiling.  Moreover  the  platform  is  equipped  with  several  analog  and  digital  inputs  allowing  the  connection  of  additional  sensor  and  sensor  systems.  The  fist  buoy  network  was  designed  based  on  2.5  GHz  RF  modules(Atmels  ATmega1281  together  with  the  AVR  Z-Link  AT86RF230).  According  the  specifications  of  the  manufacturer  under  perfect  conditions  the  maximum  transmission  range  is  about  4km.  A  maximum  buoy  to  buoy  distance  of  approximately  400m  could  be  achieved.  Instead  of  2.5  GHz  technology  the  final  version  of  the  buoys  was  then  equipped  with  868  MHz  transceivers.  A  buoy  to  buoy  distance  of  3km  was  possible.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
