A Bit-by-Bit Re-Writable Eflash in a Generic 65 nm Logic Process for Moderate-Density Nonvolatile Memory Applications
作者:Seung-Hwan Song, Ki Chul Chun, Chris H. Kim
摘要:Embedded nonvolatile memory (eNVM) is considered to be a critical building block in future system-on-chip and microprocessor systems. Various eNVM technologies have been explored for high-density applications including dual-poly embedded flash (eflash), FeRAM, STT-MRAM, and RRAM. On the other end of the spectrum, logic-compatible eNVM such as e-fuse, anti-fuse, and single-poly eflash memories have been considered for moderate-density low-cost applications. In particular, single-poly eflash memory has been gaining momentum as it can be implemented in a generic logic process while supporting multiple program-erase cycles. One key challenge for single-poly eflash is enabling bit-by-bit re-write operation without a boosted bitline voltage as this could cause disturbance issues in the unselected wordlines. In this work, we present details of a bit-by-bit re-writable eflash memory implemented in a generic 65 nm logic process which addresses this key challenge. The proposed 6 T eflash memory cell can improve the overall cell endurance by eliminating redundant program/erase cycles while preventing disturbance issues in the unselected wordlines. We also provide details of special high voltage circuits such as a voltage-doubler based charge pump circuit and a multistory high-voltage switch, for generating a reliable high-voltage output without causing damage to the standard logic transistors.
推荐帖子
评论
