pdf
An Adaptive Pre-Distortion Technique to Mitigate the DTC Nonlinearity...
  • 1星
  • 日期: 2020-12-17
  • 大小: 1.69MB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 自适应信号处理
自适应信号处理
DPLL
DPLL
数字锁相环
数字锁相环
An  Adaptive  Pre-Distortion  Technique  to  Mitigate  the  DTC  Nonlinearity  in  Digital  PLLs
作者:Salvatore  Levantino,  Giovanni  Marzin,  Carlo  Samori
摘要:Digital  fractional-N  phase-locked  loops  (PLLs)  are  an  attractive  alternative  to  analog  PLLs  in  the  design  of  frequency  synthesizers  for  wireless  applications.  However,  the  main  obstacle  to  their  full  acceptance  in  the  wireless-systems  arena  is  their  higher  content  of  output  spurious  tones,  whose  level  is  ultimately  set  by  the  nonlinearity  of  the  time-to-digital  converter  (TDC).  The  known  methods  to  improve  the  linearity  of  the  TDC  either  increase  its  dissipation  and  phase  noise  or  require  slow  foreground  calibrations.  By  contrast,  the  class  of  digital  PLLs  based  on  a  one-bit  TDC  driven  by  a  multibit  digital-to-time  converter  (DTC)  substantially  reduces  power  dissipation  and  eliminates  the  TDC  nonlinearity  issues.  Although  its  spur  performance  depends  on  DTC  linearity,  the  modified  architecture  enables  the  application  of  a  background  adaptive  pre-distortion  which  does  not  compromise  the  PLL  phase-noise  level  and  power  consumption  and  is  much  faster  than  other  calibration  techniques.  This  paper  presents  a  3.6-GHz  digital  PLL  in  65-nm  CMOS,  with  in-band  fractional  spurs  dropping  from  —39  to  —52  dBc  when  the  pre-distortion  is  enabled,  in-band  phase  noise  of  —103  dBc/Hz  and  power  consumption  of  4.2  mW.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
