pdf
Sampling Circuits That Break the kT/C Thermal Noise Limit
  • 1星
  • 日期: 2020-12-17
  • 大小: 1.25MB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 采样电路
采样电路,具有一个模拟信号输入,一个控制信号输入和一个模拟信号输出。该电路的作用是在某个规定的时刻接收输入电压,并在输出端保持该电压直至下次采样开始为止。
自动归零
作者:Ron  Kapusta,  Haiyang  Zhu,  Colin  Lyden
摘要:Several  circuit-level  techniques  are  described  which  are  used  to  reduce  or  cancel  thermal  noise  and  break  the  so-called  kT/C  limit.  kT/C  noise  describes  the  total  thermal  noise  power  added  to  a  signal  when  a  sample  is  taken  on  a  capacitor.  In  the  first  proposed  technique,  the  sampled  thermal  noise  is  reduced  by  altering  the  relationship  between  the  sampling  bandwidth  and  the  dominant  noise  source,  providing  a  powerful,  new  degree  of  freedom  in  circuit  design.  In  the  second  proposed  technique,  thermal  noise  sampled  on  an  input  capacitor  is  actively  canceled  using  an  amplifier,  so  that  the  noise  at  the  amplifier  output  can  be  controlled  independently  of  input  capacitor  size.  Measurements  from  two  test  chips  are  presented  which  demonstrate  sampled  thermal  noise  power  reduction  of  48%  and  67%,  respectively,  when  compared  with  conventional  kT/C-limited  sampling.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
