pdf
Adaptively Biased Linear Transconductor
  • 1星
  • 日期: 2020-12-22
  • 大小: 310.7KB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 偏置电路
偏置电路
差分放大器
差分放大器是能把两个输入电压的差值加以放大的电路。能把两个输入电压的差值加以放大的电路,也称差动放大器。这是一种零点漂移很小的直接耦合放大器,常用于直流放大。
作者:Susanta  Sengupta
摘要:This  paper  describes  a  new  circuit  topology  of  a  linear  transconductor.  The  conventional  differential  pair  (CDP),  with  a  constant  tail  current,  is  linearized  by  an  adaptive  biasing  scheme  ,  and  the  only  extra  elements  added  to  the  differential  pair  are  source  followers.  Compared  to  the  CDP,  the  proposed  circuit  achieves  similar  speed  and  noise  performance,  but  the  common-mode  rejection  is  compromised  at  the  expense  of  tremendous  improvement  in  linearity.  While  operating  from  a  1.8-V  power  supply  in  a  0.18μm  CMOS  process,  the  simulated  variation  in  gm  for  1-V  p-p  and  2-V  p-p  differential  input  is  1.2%  and  22%,  respectively.  Also,  the  THD  performance  for  a  1-V  p-p,  1-MHz  differential  sinusoidal  input  is  -65  dB,  which  is  about  a  40-dB  improvement  over  the  CDP.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
