pdf
Bandwidth Enhancement for Transimpedance Amplifiers
  • 1星
  • 日期: 2020-12-22
  • 大小: 978.83KB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 带宽增强
带宽增强
跨阻抗放大器
带宽增强
低通滤波器
低通滤波器是容许低于截止频率的信号通过, 但高于截止频率的信号不能通过的电子滤波装置。
作者:Behnam  Analui,  Ali  Hajimiri
摘要:A  technique  for  bandwidth  enhancement  of  a  given  amplifier  is  presented.  Adding  several  interstage  passive  matching  networks  enables  the  control  of  transfer  function  and  frequency  response  behavior.  Parasitic  capacitances  of  cascaded  gain  stages  are  isolated  from  each  other  and  absorbed  into  passive  networks.  A  simplified  design  procedure,  using  well-known  low-pass  filter  component  values,  is  introduced.  To  demonstrate  the  feasibility  of  the  method,  a  CMOS  transimpedance  amplifier  (TIA)  is  implemented  in  a  0.18-μm  BiCMOS  technology.  It  achieves  3  dB  bandwidth  of  9.2  GHz  in  the  presence  of  a  0.5-pF  photodiode  capacitance.  This  corresponds  to  a  bandwidth  enhancement  ratio  of  2.4  over  the  amplifier  without  the  additional  passive  networks.  The  transresistance  gain  is  54  dBΩ,  while  drawing  55  mA  from  a  2.5-V  supply.  The  input  sensitivity  of  the  TIA  is  -18  dBm  for  a  bit  error  rate  of  10-¹²
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
