pdf
A 12-bit 200KS/s SAR ADC with a Mixed Switching Scheme and Integer-Based...
  • 1星
  • 日期: 2020-12-25
  • 大小: 1.07MB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: SAR
该算法是第一个具有Qos意识的路由协议。该协议以基于路由表驱动的多路径方式满足网络低能耗和鲁棒性的要求。它的特点是路由决策不仅要考虑到每条路径的能源,还要涉及端到端的延迟需求和待发送数据包的优先级。
ADC
ADC,Analog-to-Digital Converter的缩写,指模/数转换器或者模拟/数字转换器。是指将连续变量的模拟信号转换为离散的数字信号的器件。真实世界的模拟信号,例如温度、压力、声音或者图像等,需要转换成更容易储存、处理和发射的数字形式。模/数转换器可以实现这个功能,在各种不同的产品中都可以找到它的身影。
《A  12-bit  200KS/s  SAR  ADC  with  a  Mixed  SwitchingScheme  and  Integer-Based  Split  Capacitor  Array》
A  low  power  successive  approximation  register  ADC  (SAR  ADC)  using  a  high  performance  integer-based  split  capacitor  array  combining  with  a  mixed  switching  strategy  is  presented  in  this  work.  The  split  capacitor  is  chosen  to  be  2  times  unit  capacitance  rather  than  the  traditional  non-integer  value  which  is  difficult  to  get.  This  array  features  high  linearity,  low  area  and  power  consumption.  Besides,  a  mixed  switching  strategy  combining  the  merged  capacitor  switching  with  monotonic  switching  is  also  used  to  save  half  of  total  capacitance.  And  a  time  domain  comparator  is  used  to  achieve  better  offset  performance.  Implemented  in  a  0.18-μm  CMOS  technology,  the  proposed  ADC  is  measured  to  have  a  65.5  dB  signal-to-noise-and-distortion  ratios(SNDR)  which  leads  to  a  10.6  effective  number  of  bits(ENOB)  at  200KS/s  sampling  rate.  Its  power  consumption  is  1.49-μW  and  figure  of  merit  (FOM)  is  only  4.87  fJ/c-s  at  a  voltage  supply  of  0.9V.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
