pdf
A 5.8 mW Continuous-Time ΔΣ Modulator With 20 MHz Bandwidth Using Time ...
  • 1星
  • 日期: 2020-12-28
  • 大小: 1.37MB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 模数转换器
模数转换器即A/D转换器,或简称ADC,通常是指一个将模拟信号转 变为数字信号的电子元件。通常的模数转换器是将一个输入电压信号转换为一个输出的数字信号。由于数字信号本身不具有实际意义,仅仅表示一个相对大小。故任 何一个模数转换器都需要一个参考模拟量作为转换的标准,比较常见的参考标准为最大的可转换信号大小。
连续时间
delta-sigma调制器
delta-sigma调制器
《A  5.8  mW  Continuous-Time  ΔΣ  Modulator  With  20  MHz  Bandwidth  Using  Time-Domain  Flash  Quantizer》
This  paper  presents  a  power-efficient  realization  of  a  third-order  continuous-time  delta-sigma  modulator  with  3-bit  time-domain  flash  quantizer  (TDFQ)  and  data-weighted  averaging  (DWA)  based  on  the  shifter  output  and  input.  Using  the  time-domain  quantizer  can  overcome  design  issues  in  low  voltage  supply  during  CMOS  downscaling.  The  modulator  uses  the  TDFQ  instead  of  a  voltage-domain  quantizer  to  reduce  power  consumption.  The  proposed  TDFQ  solves  the  linearity  problem  of  the  delay-based  voltage-to-time  converter  (VTC)  without  calibration  circuit  while  also  increasing  the  quantizer  input  range  and  saving  energy.  Moreover,  in  order  to  reduce  the  mismatch  effects  of  a  multibit  DAC  and  achieve  low  power  consumption,  implementation  of  a  low-power  DWA  circuit  is  proposed  without  using  a  digital  adder  to  calculate  pointer  for  controlling  barrel  shift  circuit.  This  chip  was  fabricated  in  CMOS  90  nm  process.  The  proposed  modulator  consumes  5.8  mW  from  1.0  V  and  achieves  peak  SNDR  of  65.3  dB  over  the  20  MHz  bandwidth,  which  results  in  FOM_W=96.3  fJ/level  and  FOM_S=161  dB.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
