pdf
Time-Interleaved Noise-Coupling Delta-Sigma Modulator Using Modified Noise...
  • 1星
  • 日期: 2020-12-28
  • 大小: 2.72MB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 模数转换器
模数转换器即A/D转换器,或简称ADC,通常是指一个将模拟信号转 变为数字信号的电子元件。通常的模数转换器是将一个输入电压信号转换为一个输出的数字信号。由于数字信号本身不具有实际意义,仅仅表示一个相对大小。故任 何一个模数转换器都需要一个参考模拟量作为转换的标准,比较常见的参考标准为最大的可转换信号大小。
delta-sigma调制器
delta-sigma调制器
噪声整形
delta-sigma调制器
《Time-Interleaved  Noise-Coupling  Delta-Sigma  Modulator  Using  Modified  Noise-Shaped  Integrating  Quantizer》
This  paper  presents  an  efficient  noise  coupling  scheme  in  time-interleaved  delta-sigma  modulators  (DSMs).  The  traditional  voltage  domain  quantization  error  extraction  is  replaced  with  time  domain  method  which  is  inherently  available  in  the  noise-shaped  integrating  quantizers  (NSIQs).  Thus,  no  digital-to-analog  converter  is  required  for  the  noise-coupling.  A  modified  NSIQ  scheme  is  proposed,  which  not  only  allows  the  use  of  the  NSIQ  with  an  even  number  of  time-interleaving,  but  also  increases  the  overall  noise  transfer  function  (NTF)  order.  Along  with  an  additional  order  of  NTF  in  the  NSIQ,  a  higher  order  NTF  can  be  achieved  by  interleaving  and  noise-coupling  multiple  channel  NSIQs  and  DSMs.  The  proposed  time-interleaved  noise-coupling  NSIQ  can  be  used  as  a  stand  alone  analog-to-digital  converter,  or  as  a  quantizer  in  time-interleaved  DSMs.  Mathematical  analysis  and  MATLAB  simulation  results  are  provided  to  prove  the  efficiency  of  the  proposed  scheme.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
