pdf
A Simple Three-Terminal IC Bandgap Reference
  • 1星
  • 日期: 2020-12-28
  • 大小: 884.11KB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 单片集成电路
单片集成电路
带隙基准
带隙基准
A  new  configuration  for  realization  of  a  stabilized  bandgap  voltage  is  described.  The  new  two-transistor  circuit  uses  collector  current  sensing  to  eliminate  errors  due  to  base  current.  Because  the  stabilized  voltage  appears  at  a  high  impedance  point,  the  application  circuits  with  higher  output  voltage  is  simplified.  Incorporation  of  the  new  two-transistor  cell  in  a  three-terminal  2.  5-v  monolithic  reference  is  described.  The  complete  circuit  is  outlined  together  with  analytical  methods  used  in  the  design.  The  analytical  results  include  sensitivity  coefficients,  gain  and  frequency  response  parameters,  and  biasing  for  optimum  temperature  performance.  The  performance  of  the  monolithic  circuit,  which  includes  temperature  coefficients  of  5  ppm/  degree  C  over  the  military  temperature  range,  is  reported.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
