pdf
Op-Amps and Startup Circuits for CMOS Bandgap References With Near 1-V Supply
  • 1星
  • 日期: 2020-12-28
  • 大小: 304.87KB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: 带隙基准
带隙基准
CMOS集成电路
CMOS集成电路
The  design  of  bandgap-based  voltage  references  in  digital  CMOS  raises  several  design  difficulties,  as  the  supply  voltage  is  lower  than  the  silicon  bandgap  in  electron  volts,  i.e.,  1.2  V.  A  current-mode  architecture  is  used  in  order  to  address  the  main  issues  posed  by  the  low  supply,  but  the  implementation  of  the  operational  amplifier  and  of  dedicated  startup  circuits  deserves  some  attention.  Even  if  nonstandard  devices  such  as  depletion-mode  MOS  transistors  may  be  helpful  to  manage  the  supply  scaling,  they  are  seldom  available  and  poorly  characterized.  Therefore,  they  must  be  avoided  in  a  robust  design  featuring  a  high  portability.  This  paper  proposes  some  circuit  solutions  suitable  for  very  low-supply-voltage  operation  and  addresses  the  main  issues  of  achieving  the  correct  bias  point  at  the  power  on.  A  few  bandgap  references  were  implemented  in  digital  0.35-  and  0.18-μm  technologies  featuring  a  nominal  output  voltage  of  about  500  mV  and  minimum  supplies  from  1.5  to  0.9  V.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
