pdf
An Improved Compensated-Temperature and High PSRR Bandgap...
  • 1星
  • 日期: 2020-12-28
  • 大小: 110.56KB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: PSRR
如果运算放大器的电源发生变化,输出不应变化,但实际上通常会发生变化。如果X (V)的电源电压变化产生Y (V)的输出电压变化,则该电源的PSRR(折合到输出端)为X/Y。
带隙基准
带隙基准
《An  Improved  Compensated-Temperature  and  High  PSRR  Bandgap  Reference  Circuit  Design》
This  paper  presents  a  BICMOS  band-gap  reference  design,  which  possesses  two  Brokaw  bandgap  references  with  an  RC  filter  at  the  output  stage.  Then  a  good  temperature  characteristic  and  a  high  power  supply  rejection  ratio  (PSRR),  suit  for  a  wide  range  of  frequency,  can  be  obtained.  The  simulation  results  show  that  within  the  frequency  range  from  100Hz  to  10MHz,  the  design  has  achieved  an  average  of  PSRR  more  than  100dB  as  well  as  a  temperature  coefficient  of  6.5  ppm  /℃  over  a  temperature  range  from  -25℃  to  110℃.  A  fast  turn-on  circuit  is  introduced  to  improve  the  turn-on  time  of  the  circuit.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
