pdf
Fully differential current-mode third-order Butterworth VHF Gm-C filter...
  • 1星
  • 日期: 2020-12-28
  • 大小: 1.69MB
  • 所需积分:1分
  • 下载次数:0
  • favicon收藏
  • rep举报
  • 分享
  • free评论
标签: CMLT
CMLT
全差分
全差分
《Fully  differential  current-mode  third-order  Butterworth  VHF  Gm-C  filter  in  0.18  lm  CMOS》
The  authors  present  a  new  fully  differential  current-mode  third-order  Butterworth  very  high  frequency  Gm-C  filter  using  current-mode  linear  transformation  (CMLT)  techniques.  The  systematic  design  method  and  procedure  are  developed  to  realise  CMLT  Gm-C  filters  efficiently.  A  third-order  Butterworth  lowpass  filter  with  200MHz  cutoff  frequency,  embedded  bandgap  reference  and  bias  circuit  is  implemented  in  a  TSMC  0.18  mm  1P6M  process.  The  total  harmonic  distortion  of  the  proposed  current-mode  filter  is  -46.5dB  at  200MHz  with  input  signal  0.4mA.  Power  dissipation  is  16.77mW  under  1.8V  supply  voltage.  Its  core  area  occupies  0.163×  0.186mm2.  Both  post-layout  simulation  and  experimental  results  confirm  the  theoretical  analysis.  The  proposed  circuits  can  be  extended  to  high-order  Chebychev  and  elliptic  filters.
更多简介内容
推荐帖子
评论
登录/注册
意见反馈
求资源
回顶部
datasheet推荐 换一换
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
$(function(){ var appid = $(".select li a").data("channel"); $(".select li a").click(function(){ var appid = $(this).data("channel"); $('.select dt').html($(this).html()); $('#channel').val(appid); }) })
