热搜关键词: Protel 99SE欧姆龙PLCGD32变压器
pdf
PI设计指导
  • 1星
  • 2022-07-04
  • 329.17KB
  • 需要1积分
  • 0次下载
  • favicon收藏
  • rep举报
  • free评论
标签: 电子电路
电子电路
PI设计指导PI设计指导PI设计指导
Power Integrations - Power Puzzler 1
POWER
puzzler
张飞实战电子官方½站:www.zhangfeidz.com
☜点击打开
(广告勿扰100%拒绝水贴,10名疯狂工程师运营的½站,有问必答)
Understanding the Effects of Diodes
by Peter Vaughan
Manager of Product Applications
Power Integrations
The schematic below shows a Flyback power supply built with a
TOPSwitch
-GX
power conversion IC. The following questions concern the selection of the
output diode (D3) and the clamp diode (D1).
Question 1: beginner
Which diode or diodes from the following list are suitable for use as D3 and why?
a.
b.
c.
d.
e.
f.
80 V, 5 A, Schottky (e.g. SB580)
600 V, 3 A, Ultrafast (e.g. UF5406)
50 V, 3 A, Rectifier (e.g. 1N5400)
100 V, 8 A, Ultrafast (e.g. BYV29-100)
45 V, 7.5 A, Schottky (e.g. MBR745)
1000 V, 2.5 A, Fast (e.g. FR257)
Click to see the Answer
Input: 90-375 VDC
Output: 12 V, 2.5 A
http://www.powerint.com/powerpuzzler050308/(第 1/8 页)2007-8-9 2:08:09
☜点击打开
Answer:
a and d
☜点击打开
Suitability of Diode Parameters
Diode
(a) SB580
(b) UF5406
(c) 1N5400
Diode Parameters
80 V, 5 A
600 V, 3 A, 75 ns
50 V, 3 A, 2000 ns
Peak Reverse
Voltage (V
RRM
Average Forward
Current (I
AVE
X*
Reverse Recovery
Time (t
rr
(d) BYV29-100
(e) MBR745
(f) FR257
100 V, 8 A, 25 ns
45 V, 7.5 A
1000 V, 2.5 A, 500 ns
* With bench verification of temperature rise
Why?:
In selecting the output rectifier three key parameters should be considered; voltage rating, current rating and reverse recovery time.
Considering each of these in turn we can see which of the diodes is suitable.
Maximum repetitive reverse voltage (V
RRM
Ideally the diode selected should have a V
RRM
rating 1.25·V
, where V
is the reverse voltage seen by the diode. The 1.25 de-rating factor provides margin to take
account of leakage inductance generated voltage spikes, and AC line transients that increase the DC bulk voltage temporarily plus reducing the device stress improves
reliability.
Normally where people get into trouble is determining the value of V
. You’d be forgiven for thinking that the reverse voltage seen by the diode is just the output
voltage, here 12 V so anything above a 15 V diode would be fine. However the anode of D3 is connected to a Flyback transformer. This means that when the MOSFET
inside U1 turns on, under maximum input line of 375 VDC (265·VAC x √2) is seen across the primary. This voltage is transformed by the primary to secondary
turns ratio and due to the phase of the windings drives the anode of the output diode negative. In this design the value of V
is given by:
= V
+ (V
MAX
)·(N
/N
= 12 + 375·6/58
= 50.7 V
http://www.powerint.com/powerpuzzler050308/(第 2/8 页)2007-8-9 2:08:09
这个公式是很重要的,在MOSFET导通的瞬间,
初级有一个电势会耦合到次级, 和输出滤波电容器两端
电压成串联叠加 D3
两端。
☜点击打开
☜点击打开
Applying the 1.25 V de-rating this gives a minimum diode rating of 63 V. The closest standard diode rating would be an 80 V Schottky or a 100 V PN diode.
Therefore all the diodes have an acceptable V RRM rating except (c) and (e).
Forward Current Rating (I
AVE
Diodes manufacturers generally specify the current rating as the average current through the diode or for a Flyback power supply the load current. In this design the
specified output current is 2.5 A so a diode with a current rating above 2.5 A is acceptable right? Yes and no.
这句话的意思是1N54系列:
从厂商提供的降额曲线来看3A
的管子在引线周围温度为100摄氏度时实际上最多只½通过1.5A
的平均电流。
The diode manufacturers provide de-rating curves so for example at a lead temperature of 100 °C a 3 A PN diode is actually a 1.5 A diode!
Diode type. The choice between PN and Schottky and the actual voltage rating changes a diode’s forward voltage. The lower the forward voltage drop, the
lower the dissipation is for a given forward current.
Overload fault conditions. All power supplies have some degree of overload capability. Due to tolerances a typical supply will be able to deliver significantly
more than the specified output power, especially at high line. Therefore if an overload condition can exist then the diode should be sized to operate without
overheating and failing. Products from Power Integrations significantly help here as the key parameters associated with power delivery (frequency and current
limit) are very tightly specified, reducing the overload power. In addition line voltage power limiting is easy to add to reduce overload power. In this example the
addition of R2 reduced the primary current limit as the line voltage increases and provides a very flat overload power characteristic with line voltage as shown
below.
As a general rule of thumb select the current rating such that I
AVE
= 3 x I
irrespective if the diode is a PN or a Schottky type (although a Schottky diode will have lower
dissipation check the maximum operating temperature – some are 25-50 ° C lower than a PN diode). Finally measure the diode temperature under maximum
overload power, highest ambient to check it is within either internal or manufacturers design limits.
Looking at the diodes in the list to determine if they are acceptable or not:
Rated
AVE
5A
Diode
(a) SB580
Acceptable?
Yes - based on bench I
AVE
is only 2 x I
it’s a Schottky diode has a
verification
maximum temperature specification of 150 C
and used in a supply with power limiting (R2
and R4 in schematic) so it’s likely this diode
would be acceptable.
No
No
No
AVE
is only 1 or 1.2 x I
- diodes would
overheat
(b) UF5406
(c) 1N5400
(f) FR257
3A
3A
2.5 A
http://www.powerint.com/powerpuzzler050308/(第 3/8 页)2007-8-9 2:08:09
☜点击打开
(d) BYV29-100
8A
Yes
☜点击打开
AVE
is ≥3 x I
and in a TO220 package. When
attached to a suitable heatsink this diode is a
good choice.
So diodes (a), (d) and (e) have an acceptable current rating but if you ruled out (a) that would also be ok.
Reverse recovery time (t
rr
An ideal diode would instantly block reverse current flow when a reverse bias is applied. In practice a Schottky approaches zero recovery time however for a PN diode
it takes a finite time for charge stored in the diode to be swept away before it can block. The amount of charge is proportional to the current flowing through the diode.
This is significant as even a Flyback converter operating in discontinuous conduction mode will actually operate in continuous conduction mode at start-up meaning
the output diode has to reverse recover with a significant forward current flowing. In this design the converter operates in continuous conduction mode some the diode
has to recover with forward current on every switching cycle.
To prevent large reverse currents from flowing through the diode when the MOSFET in U1 turns on, applying a reverse voltage, the diode should have a reverse
recovery time less than switching time. This means a recovery time of 50 ns or better.
Longer duration than this causes large primary side current spikes at the turn on event and high diode dissipation – for example the 1N5400 became hot enough to
melt the solder holding into the PCB while taking the measurements for question 2.
Diode
(a) SB580
(b) UF5406
(c) 1N5400
(f) FR257
(d) BYV29-100
(e) MBR745
rr
75 ns
500 ns
25 ns
Acceptable?
Yes
No
No
No
Yes
Yes
Not specified but >>2000 ns
So diodes (a), (d) and (e) have an acceptable reverse recovery time.
http://www.powerint.com/powerpuzzler050308/(第 4/8 页)2007-8-9 2:08:09
☜点击打开
☜点击打开
Question 2: advanced
Below is a series of oscillograms showing the drain voltage (V
DS
) and current (I
) of U1, measured with the different diodes listed in question 1*. Can you match
the resultant waveforms to the diode(s) that generated them?
Waveform 1: ________
Waveform 2: ________
Waveform 3: ________
Waveform 4: ________
*Test Conditions: 1.5 A load @ 115 V AC; Upper Trace V
DS
=100 V/div; Lower Trace I
=0.4 A/div, 2
µs/div
http://www.powerint.com/powerpuzzler050308/(第 5/8 页)2007-8-9 2:08:09
☜点击打开
展开预览
推荐帖子 最新更新时间:2022-08-11 04:23
电路中元器件筛选的原则
01  元器件筛选的必要性       电子元器件的固有可靠性取决于产品的可靠性设计,因此,应该在电子元器件装上整机或设备之前,就要设法尽可能排除掉存在问题的元器件,为此就要对元器件进行筛选。那么,元器件筛选都有哪些方案?原则是什么?常见的筛选项目有哪些? 安排测试筛选先后次序的两种方案: 方案1:将不产生连环引发效果的失效模式筛选放在前面,将可以与其它失效模式产生连环引发效果的失效
qwqwqw2088 模拟与混合信号
有奖直播预报名:ADI在可穿戴产品中的生命体征监测解决方案
随着电子技术的不断发展以及云计算,物联网(IoT)和5G等通信技术的新突破,数字医疗得到了迅速扩张和采用。生命体征监测(VSM)功能已越来越多地内置于手机、手表和其他智能可穿戴设备中,这些设备能够测量各种生命体征和健康指标,例如体温、心率、呼吸、血氧饱和度(SpO2)、血压和身体成分等,同时由于优秀的功耗控制,更便携的使用体验使得对身体的24小时连续监测成为可能,COVID-19大流行也导致对小型
EEWORLD社区 便携医疗电子
F28335控制无刷直流电机出现cap中断进入一遍后不再进入
ECap1Regs.ECCTL1.bit.CAP1POL = EC_RISING;   ECap1Regs.ECCTL1.bit.CAP2POL = EC_FALLING;   ECap1Regs.ECCTL1.bit.CAP3POL = EC_RISING;   ECap1Regs.ECCTL1.bit.CAP4POL = EC_FALLING;   ECap1Regs.ECCTL1.
garyjhon DSP 与 ARM 处理器
Android4.4.2 源码编译-iMX6Q/D核心板-非设备树源码
5.3.1 Android 源码整体编译-基于迅为-IMX6开发板系列 本节介绍如何将 Android 源码如何整体编译,即将 uboot,kernel,Android 镜像一次 性全部编译出来。 注意:编译 Android 系统必须保证给 Ubuntu 系统提供 4G 以上内存。这里“提供 4G 以 上内存”的意思,不仅仅是指在 VMware Workstations 虚拟机中设置分配
马佳徐徐 嵌入式系统
【转帖】元器件知识点----选型与故障分析
当中的控制模块(驱动模块,集联模块,PWM产生模块等),在MCU的设计过程之中悬空的引脚也需要关注的是上拉或者是下拉,因为悬空的引脚会对静态电流会有相对应的影响。磁珠 磁珠选型时要注意冲击电流问题。常用0805和0603封装磁珠承受冲击电流建议。 多脉冲且微秒级 :10 ~ 40 倍额定电流 单脉冲 5~20uS,30~500倍额定值,如果是多脉冲降额到 30% 使用 1A 通流能力磁珠可
Ameya360皇华 综合技术交流
Proteus 8.6 仿真问题
本帖最后由 shinykongcn 于 2017-4-16 17:02 编辑 新装的河蟹版Proteus 8.6,听说可以仿真stm32,从坛友在 这里 分享的帖子下载的,下载之后直接安装了,安装在默认的位置,然后打开examples里面的工程,出如下错误: symbol $mkrorigin used but not found in libraries. 除了这个错误外,第一次打开
shinykongcn 单片机
评论
登录/注册
意见反馈
求资源
回顶部
查找数据手册?
EEWorld Datasheet 技术支持
热门活动
相关视频
可能感兴趣器件
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2022 EEWORLD.com.cn, Inc. All rights reserved
