热搜关键词: MATLAB天线OpenCVVHDL
pdf
power 设计实例
  • 1星
  • 2022-07-04
  • 815.83KB
  • 需要1积分
  • 0次下载
  • favicon收藏
  • rep举报
  • free评论
标签: 电源
电源
power  设计实例power  设计实例power  设计实例power  设计实例
张飞实战电子官方½站:www.zhangfeidz.com
☜点击打开
(广告勿扰100%拒绝水贴,10名疯狂工程师运营的½站,有问必答)
Title
Specification
Customer
Application
Author
Document Number
Date
Revision
Engineering Report – 65W Single Output
Adapter, iW2210
Input: 90 – 265 V
AC
Output: 19V / 3.5A @65W max.
Various
Adapter for Various Applications
iWatt Applications Department
AE-4003
July 11, 2005
NR
Summary and Features
Compact size (100 x 41.5 x 25mm)
Designed to achieve low cost & part count
Designed to meet both conducted & radiated EMI requirements
A Production ready model that meets safety requirements
iWatt, Inc.
90 Albright Way,
Los Gatos, CA 95032-1827 USA.
Tel: 408-374-4200 Fax: 408-341-0455
www.iwatt.com
☜点击打开
☜点击打开
AE-4003
iW2210, 65W Single Output Adapter
Date :
July 11,2005
Page 2 of 31
Rev : NR
Table Of Contents
Power Supply Specification ............................................................................................. 6
Schematic........................................................................................................................ 7
Circuit Description ........................................................................................................... 8
Bill of Materials ................................................................................................................ 9
PCB Layout ................................................................................................................... 11
Transformer Specification.............................................................................................. 12
6.1
6.2
6.3
6.4
6.5
6.6
Bobbin Outline ...................................................................................................... 12
Electrical Diagram ................................................................................................ 12
Electrical Specifications ........................................................................................ 12
Construction ......................................................................................................... 13
Materials ............................................................................................................... 13
Others Assembly Details ...................................................................................... 14
Inductor Specification .................................................................................................... 14
7.1
7.2
7.3
CM Inductor (L2)................................................................................................... 14
Output Filter Inductor (L3) .................................................................................... 15
CM Inductor (L4)................................................................................................... 15
Static Electrical Performance ........................................................................................ 16
8.1
8.2
8.3
Efficiency .............................................................................................................. 16
No-load Input Power............................................................................................. 16
Regulation ............................................................................................................ 17
8.3.1 Load ...........................................................................................................17
8.3.2 Line ............................................................................................................ 17
8.4
8.5
Output V-I Characteristics Curve .......................................................................... 18
Ripple and Noise Voltage ..................................................................................... 19
8.5.1 Output ripple voltage .................................................................................. 20
8.5.2 Output ripple waveform .............................................................................. 20
Thermal Performance.................................................................................................... 21
10 Transient Performance .................................................................................................. 22
10.1 Inrush Current....................................................................................................... 22
10.2 Start Up & Turn on Delay ..................................................................................... 23
10.3 Shut Down & Hold Up Time.................................................................................. 24
iWatt, Inc.
90 Albright Way, Los Gatos, CA 95032-1827 USA. Tel: 408-374-4200 Fax: 408-341-0455
☜点击打开
www.iwatt.com
☜点击打开
AE-4003
Date :
July 11,2005
Page 3 of 31
Rev : NR
10.4 Dynamic Load Response ..................................................................................... 25
11 Protection Circuit ........................................................................................................... 26
11.1 Over Current Protection........................................................................................ 26
11.2 Short Circuited Protection..................................................................................... 26
11.3 Over Voltage Protection ....................................................................................... 26
12 Major Operational Waveform......................................................................................... 27
12.1 Drain Voltage and Current, Max Load .................................................................. 27
12.2 Drain Voltage and Current during Start-up ........................................................... 28
13 EMC Test ...................................................................................................................... 29
13.1 Conducted EMI..................................................................................................... 29
13.2 Power Line Transient............................................................................................ 30
14 Revision History............................................................................................................. 31
iWatt, Inc.
☜点击打开
www.iwatt.com
☜点击打开
AE-4003
Date :
July 11,2005
Page 4 of 31
Rev : NR
Important Note: (Read this before using this document)
This document and the information provided herein are solely for design and engineering
reference (includes safety and related requirements). iWatt is not responsible for any claim of
damage resulting from the use of these materials.
This test report describes a 65W converter which utilizes iWatt 2210, an advanced digital PWM
controller that delivers 19V, 3.5A (or 65W) of power.
This design aims for low cost and meets EMI and most Immunity requirements.
The following information is included in this test report: schematic, bill of materials, transformer
documentation, printed circuit layout and performance data. For additional information please
email
sales@iwatt.com
or visit our website at
http://www.iwatt.com.
iWatt, Inc.
☜点击打开
www.iwatt.com
☜点击打开
AE-4003
Finished Assembly
Date :
July 11,2005
Page 5 of 31
Rev : NR
Component side (Top)
Solder side (Bottom).
iWatt, Inc.
☜点击打开
www.iwatt.com
展开预览
推荐帖子 最新更新时间:2022-08-08 09:14
R7F0C809A/D 转换器(软件触发、单次转换模式)操作流程
本篇应用说明介绍了 R7F0C809 使用 A/D 转换器(软件触发、单次转换模式),对模拟电压进行 A/D 转换 的方法。 在本篇应用说明中,对 A/D 转换结果进行数据转换,然后将转换值保存在内部 RAM 中。 http://documentation.renesas.com/doc/products/region/rtcn/mpumcu/apn/r01an2454cc010
gaoyang9992006 瑞萨电子MCU
无线电对讲机通话距离的解释
在无线通信的专业里,没有距离这个技术参数,您会发现,厂家给出的距离都会加上一个理论值,这个理论值都是在完全没有任何障碍物的理想环境下得出的,参考意义不大,因为实际使用距离它本身就不是一个固定参数,它会受到诸多因素的影响。 常规无线电对讲机不依靠任何网   在无线通信的专业里,没有“距离”这个技术参数,您会发现,厂家给出的“距离”都会加上一个“理论值”,这个理论值都是在完全没有任何障碍物的理想环境
Jacktang RF/无线
TI and Ford SYNC® 3- Redefining User Experience
Integration of TI's processor, connectivity and analog solutions enhances connected car capabilities. $('swf_Ud0').innerHTML=AC_FL_RunContent('width', '600', 'height', '500', 'allowNetworking', 'inte
德州仪器_视频 DSP 与 ARM 处理器
【R7F0C809】自动灌溉之二-搭个台子
这个R7F0C809花了不少时间搭台子,开发环境。经验不提,单说教训。 1. 不能用开发板的CubeSuite+, 只是因为是2.01版本的。2.不能用网上下的CS+3.01及以上版本的,因为这些版本不支持R7F0C809,这个是专门针对中国地区的RL78精简版,极精简的内存系统。3.只能用CubeSuite+2.02, 因为现在提供的DeviceInformation是适合此版本的,3.0开始
fyaocn 瑞萨电子MCU
Zigbee无线通知设备(CC2530)
最近做了一个使用Zigbee做生产线通知仓库送料设备。功能很简单,就是发送器按键按下,接收器接收到发送器数据后,报警并回应,发送器在接收到回应后,指示灯点亮表示数据发送成功。在这个过程中,遇到最大的问题就是传输距离的问题,因为在厂房内部产线和仓库之间隔了很多机器,又有一层比较厚的水泥墙。造成无线信号在传输的过程中有较大的损耗。所以只要改功率和接受灵敏度了,参考了这个网址http://blog.cs
she_xiang 无线连接
mps430与rc522模块
#include "msp430x14x.h" #include "PIN_DEF.H" #include "RC522.H" #include "UART0_Func.c" #include "ctype.h" #include "BoardConfig.h" unsigned char UID[5],Temp[4]
Aguilera 微控制器 MCU
评论
登录/注册
意见反馈
求资源
回顶部
查找数据手册?
EEWorld Datasheet 技术支持
热门活动
相关视频
可能感兴趣器件
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2022 EEWORLD.com.cn, Inc. All rights reserved
