张飞实战电子官方½站:www.zhangfeidz.com
☜点击打开
(广告勿扰100%拒绝水贴,10名疯狂工程师运营的½站,有问必答)
Half-Bridge
Power Converter Design
Using the
LM5035
Presented by Steve Schulte
Hello! Welcome to National Semiconductor’s continuing series of On-Line Seminars
The topic of this presentation is the design of Half-Bridge Power Converters.
☜点击打开
☜点击打开
Steve Schulte
Applications Engineer
Phoenix Design Center
Power Management Group
My name is Steve Schulte and I’m an applications engineer for the High Voltage
product line in the Power Management group.
张飞实战电子官方½站:www.zhangfeidz.com ☜点击打开
☜点击打开
Presentation Outline
What is a Half-Bridge Converter
How Does a Half-Bridge Work
Loop Compensation
What are the Features of the LM5035
LM5035 Evaluation Board
Other Applications of the LM5035
© 2006 National Semiconductor Corporation
The first section of this seminar will describe the Half-Bridge topology and contrast it
with other topologies.
Next we’ll delve into the power flow through the transformer, the heart of the
converter.
Then loop compensation analysis and design process for a Type 3 compensator is
presented.
Following this, the features of the LM5035 Half-Bridge Controller and Driver are
reviewed, along with the reference design and a couple alternate uses for the
LM5035.
☜点击打开
☜点击打开
Half-Bridge Description
First, what is a Half-Bridge converter?
☜点击打开
☜点击打开
Converter
Half-Bridge Converter is a Buck Topology with
Transformer-Isolation
Half the voltage stress compared to Forward
topology
Half the Transformer Volume compared to Forward
topology
Twice the effective switching frequency compared to
Forward topology
Up to 100% utilization of transformer
Used extensively in the 100W to 500W range,
possible up to 1000W
The Half-Bridge topology is derived from the Buck converter family, which also
includes the Forward topology and the Full-Bridge topology. This family transfers
power from the primary to the secondary during the ‘on’ time, rather than storing
energy in the transformer as in the Flyback topology.
The Half-Bridge returns the core magnetizing energy to the input capacitors through
the MOSFETs, so a reset method required for Forwards is not necessary. The
Forward typically causes the MOSFET drain voltage to double the VIN during reset.
Forward uses the transformer in one direction, while Half-Bridge uses the core’s
entire B-H loop. This makes better use of the Half-Bridge core so the transformer
can be smaller for the same power level.
During the switching cycle the Forward drives one power pulse and Half-Bridge
drives two. The output filter components can be smaller for Half-Bridge due to this.
Forward needs at least 30% of the switching cycle for core reset, Half-Bridge can
use up to all the switching cycle.
Full-Bridge applies twice the voltage to the transformer compared to Half-Bridge, so
the current levels are more manageable at power levels greater that 1KW.
☜点击打开
评论
