热搜关键词: MATLAB天线OpenCVVHDL
pdf
Design Guidelines for RCD Snubber of Flyback Converters
  • 1星
  • 2022-08-01
  • 174.99KB
  • 需要1积分
  • 2次下载
  • favicon收藏
  • rep举报
  • free评论
标签: 电源
电源
张飞实战电子官方½站:www.zhangfeidz.com
☜点击打开
(广告勿扰100%拒绝水贴,10名疯狂工程师运营的½站,有问必答)
www.fairchildsemi.com
Application Note AN-4147
Abstract
This article presents some design guidelines for the RCD
snubber of flyback converters. When the MOSFET turns off,
a high-voltage spike occurs on the drain pin because of a res-
onance between the leakage inductor (L
lk
of the main trans-
former and the output capacitor (C
OSS
) of the MOSFET. The
excessive voltage on the drain pin may lead to an avalanche
breakdown and eventually damage the MOSFET. Therefore,
it is necessary to add an additional circuit to clamp the volt-
age.
is derived from a buck-boost converter by replacing filter
inductors with coupled inductors, such as gapped core trans-
formers. When the main switch turns on, the energy is stored
in the transformer as a flux form and is transferred to output
during the main switch off-time. Since the transformer needs
to store energy during the main switch on-time, the core
should be gapped. Since flyback converters need very few
components, it is a very popular topology for low- and
medium-power applications such as battery chargers, adapt-
ers, and DVD players.
Figure 1 shows a flyback converter operating in continuous
conduction mode (CCM) and discontinuous conduction
mode (DCM) with several parasitic components, such as pri-
mary and secondary leakage inductors, an output capacitor
of MOSFET, and a junction capacitor of a secondary diode.
Introduction
One of the most simple topologies is a flyback converter. It
i
d
i
i
d
i
diode reverse
recovery current
i
d
j
n:
in
lk2
m
i
m
i
Vo
ds
resonance between
lk1
and C
oss
in
+nVo
lk1
(b) CCM operation
i
d
ds
oss
i
d
i
i
d
i
i
d
(a) Configuration with parasitic components
resonance between
m
and C
oss
in
+nVo
in
ds
resonance between
lk1
and C
oss
(c) DCM operation
Figure 1. Flyback Converter; (a) Configuration with Parasitic Components, (b) CCM Operation, (c) DCM Operation
© 2006 Fairchild Semiconductor Corporation
Rev. 1.1.0
☜点击打开
☜点击打开
AN-4147
APPLICATION NOTE
When the MOSFET turns off, the primary current (i
d
charges C
OSS
of the MOSFET in a short time. When the
voltage across C
OSS
(V
ds
) exceeds the input voltage plus
reflected output voltage (V
in
+nV
o
), the secondary diode
turns on, so that the voltage across the magnetizing inductor
(L
m
) is clamped to nV
o
. There is, therefore, a resonance
between L
lk1
and C
OSS
with high-frequency and high-volt-
age surge. This excessive voltage on the MOSFET may
cause failure. In the case of the CCM operation, the second-
ary diode remains turned on until the MOSFET is gated on.
When the MOSFET turns on, a reverse recovery current of
the secondary diode is added to the primary current, and
there is a large current surge on the primary current at the
turn-on instance. Meanwhile, since the secondary current
runs dry before the end of one switching period in the case of
the DCM operation, there is a resonance between L
m
and
OSS
of the MOSFET.
i
d
i
peak
i
sn
s
i
Snubber design
The excessive voltage due to resonance between L
lk1
and
OSS
should be suppressed to an acceptable level by an addi-
tional circuit to protect the main switch. The RCD snubber
circuit and key waveforms are shown in Figures 2 and 3. The
RCD snubber circuit absorbs the current in the leakage
inductor by turning on the snubber diode (D
sn
) when V
ds
exceeds V
in
+nV
o
. It is assumed that the snubber capacitance
is large enough that its voltage does not change during one
switching period.
When the MOSFET turns off and V
ds
is charged to V
in
+nV
o
the primary current flows to C
sn
through the snubber diode
(D
sn
). The secondary diode turns on at the same time. There-
fore, the voltage across L
lk1
is V
sn
-nV
o
. The slope of i
sn
is as
follows:
ds
sn
in
nV
o
Figure 3. Key Waveforms of
the
Flyback Converter with
RCD Snubber in DCM Operation
where i
sn
is the current that flows into the snubber circuit,
sn
is the voltage across the snubber capacitor C
sn
, n is the
turns ratio of the main transformer, and L
lk1
is the leakage
inductance of the main transformer. The time t
s
is obtained
by:
nV
o
di
sn
sn
dt
lk1
i
in
sn
sn
sn
sn
lk
i
sn
i
d
ds
n:1
Vo
s
lk1
i
peak
sn
nV
o
(2)
where i
peak
is the peak current of the primary current.
The snubber capacitor voltage (V
sn
) should be determined at
the minimum input voltage and full-load condition. Once V
sn
is determined, the power dissipated in the snubber circuit at
the minimum input voltage and full-load condition is
obtained by:
sn
sn
i
peak
s
f
s
sn
lk
i
peak 2
f
s
sn
nV
o
(3)
where f
s
is the switching frequency of the flyback converter.
sn
should be 2~2.5 times of nV
o
. Very small V
sn
results in a
severe loss in the snubber circuit, as shown in the above
equation.
Figure 2. Flyback Converter with RCD Snubber
Rev. 1.1.0
张飞实战电子官方½站:www.zhangfeidz.com ☜点击打开
☜点击打开
AN-4147
APPLICATION NOTE
On the other hand, since the power consumed in the snubber
resistor (R
sn
) is V
sn2
/R
sn
, the resistance is obtained by:
Example
An adapter using FSDM311 has following specifications:
85V
ac
to 265V
ac
input voltage range, 10W output power, 5V
output voltage, and 67kHz switching frequency. When the
RCD snubber uses a 1nF snubber capacitor and 480kΩ snub-
ber resistor, Figure 4 shows several waveforms with 265V
ac
at the instance of the AC switch turn-on.
sn
sn 2
sn
lk1
i
peak 2
f
s
sn
nV
o
(4)
The snubber resistor with the proper rated power should be
chosen based on the power loss. The maximum ripple of the
snubber capacitor voltage is obtained as follows:
Δ
sn
sn
sn
sn
f
s
(5)
In general, 5~10% ripple is reasonable. Therefore, the snub-
ber capacitance is calculated using the above equation.
When the converter is designed to operate in CCM, the peak
drain current, together with the snubber capacitor voltage,
decreases as the input voltage increases. The snubber capaci-
tor voltage under maximum input voltage and full-load con-
dition is obtained as follows:
sn2
nV
o
( nV
o
2R
sn
lk1
f
s
( I
peak 2
Figure 4. Start-up Waveforms with 1nF Snubber Capacitor
and 480kΩ Snubber Resistor
where f
s
is the switching frequency of the flyback converter,
lk1
is the primary-side leakage inductance, n is the turns
ratio of the transformer, R
sn
is the snubber resistance, and
peak2
is the primary peak current at the maximum input volt-
age and full-load condition. When the converter operates in
CCM at the maximum input voltage and full-load condition,
the I
peak2
peak 2
in
(V
DC max
nV
o
DC
max
nV
o
DC max
nV
o
2L
m
f
s
(V
DC
max
In Figures 4-7, Channel 1 through 4 stand for the drain volt-
age (V
ds
, 200V/div), the supply voltage (V
CC
, 5V/div), the
feedback voltage (V
fb
, 1V/div), and the drain current (I
d
0.2A/div), respectively. The maximum voltage stress on the
internal SenseFET is around 675V, as shown in Figure 4.
The voltage rating of FSDM311 is 650V, according to the
datasheet. There are two reasons for the excess of the voltage
ratings: the wrong transformer design and/or the wrong
snubber design. Figure 5 shows the reason.
nV
o
(7)
When the converter operates in DCM at the maximum input
voltage and full-load condition, the I
peak2
is obtained by:
574V
451V
peak 2
2P
in
f
s
m
(8)
where P
in
is the input power, L
m
is the magnetizing induc-
tance of the transformer, and V
DCmax
is the rectified maxi-
mum input voltage in DC value.
Verify that the maximum value of V
ds
is below 90% and
80% of the rated voltage of the MOSFET (BV
dss
), at the
transient period and steady-state period, respectively. The
voltage rating of the snubber diode should be higher than
BV
dss
. Usually an ultra-fast diode with 1A current rating is
used for the snubber circuit.
Figure 5. Steady-State Waveforms with 1nF Snubber
Capacitor
Rev. 1.1.0
☜点击打开
☜点击打开
AN-4147
APPLICATION NOTE
For the reliability, the maximum voltage stress at the steady
state should be equal to 80% of the rated voltage (650V
* 0.8
= 520V).
Figure 5 shows the voltage stress on the internal
SenseFET is above 570V with V
in
= 265V
ac
at steady state.
However, the fact that V
in
+nV
o
is around 450V (=
375V +
15 * 5V)
implies the turns ratio of the transformer is 15,
which is a reasonable value. Therefore, the snubber circuit
should be redesigned.
Let V
sn
be twice that of nV
o
, 150V, and L
lk1
and i
peak
is 150
µH and 400mA by measuring, respectively. Obtain the
snubber resistance as follows:
sn 2
sn
lk1
i
peak 2
f
s
sn
nV
o
μ
0.4
67k
(9)
sn
14k
Figure 7. Steady-State Waveforms with 10nF Snubber
Capacitor and 14kΩ Snubber Resistor
The power emission from R
sn
is calculated as follows:
The voltage stresses on the internal SenseFET are 593V and
524V at the startup and steady state, respectively. These are
around 91.2% and 80.6% of the rated voltage of FSDM311,
respectively.
(10)
sn 2
1.6W
sn
14k
Let the maximum ripple of the snubber capacitor voltage be
10% and the snubber capacitance is obtained as follows:
sn
sn
10nF
Δ
sn
sn
f
s
14k
67k
(11)
The results with 14k
(3W) and 10nF are shown in Figures
6 and 7.
Figure 6. Start-up Waveforms with 10nF Snubber
Rev. 1.1.0
☜点击打开
☜点击打开
AN-4147
APPLICATION NOTE
by Gwan-Bon Koo/ Ph. D
FPS Application Group / Fairchild Semiconductor
Phone +82-32-680-1327
Fax
+82-32-680-1317
E-mail koogb@fairchildsemi.co.kr
DISCLAIMER
FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS
HEREIN TO IMPROVE RELIABILITY, FUNCTION, OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE
APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS
PATENT RIGHTS, NOR THE RIGHTS OF OTHERS.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS
WITHOUT THE EXPRESS WRITTEN APPROVAL OF THE PRESIDENT OF FAIRCHILD SEMICONDUCTOR CORPORATION.
As used herein:
1.Life support devices or systems are devices or systems which,
(a) are intended for surgical implant into the body, or
(b) support or sustain life, or
(c) whose failure to perform when properly used in accordance with
instructions for use provided in the labeling, can be reasonably
expected to result in significant injury to the user.
Rev. 1.1.0
2.A critical component is any component of a life support device or
system whose failure to perform can be reasonably expected to
cause the failure of the life support device or system, or to affect its
safety or effectiveness.
☜点击打开
展开预览
推荐帖子 最新更新时间:2022-08-12 17:28
使用IP产生PLL时钟,出现ISE警告1127,如何消除!
本帖最后由 DevilMayCry 于 2017-11-5 23:51 编辑 如题,ISE14.7  用IP产生PLL时钟,总会出现两个警告如下: HDLCompiler:1127 - "C:\Users\...\ipcore_dir\PLL_FOR_CLOCK.v" Line 131: Assignment to locked_int ignored, since the identifi
DevilMayCry EE_FPGA学习乐园
速度与激情:更持久耐用的电动摩托车16S-17S锂离子电池组
随着快递服务需求的快速增长,电动摩托车因其电池容量大于电动自行车和电动踏板车的优势而变得越来越受欢迎。容量越大,行驶时间就越长,这有助于节省时间,并实现更长距离的递送。 电动摩托车电池组有多个电压平台,其中最普遍的是60V,它在一个电池组中需要16S或者17S锂离子电池。 实现更长的运行时间需要解决三个设计难题: 高精度电池电压采样以提高电池容量计算精度。 电池电压平衡
alan000345 TI技术论坛
FAQ:利用安全元件进行配件身份验证|Microchip 安全解决方案系列研讨会 第11场
直播主题: 利用安全元件进行配件身份验证|Microchip 安全解决方案系列研讨会 第11场   内容简介: 您是否期望保护您的收益、品牌或知识产权?那就一起回顾此次在线研讨会吧,了解Microchip适用于CryptoAuthentication™系列的可信平台中的安全元件如何助您实现配件和外设的身份验证。Microchip 利用预配置的ATECC608A TrustFlex安全元
EEWORLD社区 嵌入式系统
移动机器人的三大关键技术
在机器人领域所要研究的问题非常多,会涉及到计算机、传感器、人机交互、防生学等多个学科,其中环境感知、自主定位和运动控制是机器人技术的三大重点问题,以下将针对这三点进行详细探讨。 环境感知 目前,在机器人室内环境中,以激光雷达为主,并借助其他传感器的移动机器人自主环境感知技术已相对成熟,而在室外应用中,由于环境的多变性及光照变化等影响,环境感知的任务相对复杂的多,对实时性要求更高,使得多
eastin8 移动便携
温度过高对LED显示屏的影响
此内容由EEWORLD论坛网友罗姆液晶技术站原创,如需转载或用于商业用途需征得作者同意并注明出处 1:温度过高对LED显示屏有毁灭性的破坏 (1)LCD一般以硅胶封装,如果结温超过固相转变温度(一般为125℃),封装的材料往橡胶状态转变并极速加快热膨胀,从而导致LCD液晶屏开路和失效。 (2)LCD屏的工作温度超过芯片的最高承载温度会是其发光率快速降低从而产生光衰,那LCD的寿命就是通过光衰
罗姆液晶技术站 综合技术交流
Wi-Fi滤波器技术知多少?
常用滤波器技术是体声波(BAW)。它最适合1 GHz或更高的频率;由于Wi-Fi的频率范围为2.4GHz、5GHz,包括即将迎来的6 GHz,因此BAW技术在这些频率范围内均非常适用。 BAW具有卓越的插损性能,有助于将RF路径损耗降至最低。BAW的其它优势包括其陡峭的带缘和卓越的热耗散特性。 BAW滤波器采用固贴式谐振器(SMR)结构,与薄膜体声波谐振器(FBAR)等其它滤波器技术相
alan000345 RF/无线
评论
登录/注册
意见反馈
求资源
回顶部
查找数据手册?
EEWorld Datasheet 技术支持
热门活动
相关视频
可能感兴趣器件
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2022 EEWORLD.com.cn, Inc. All rights reserved
