热搜关键词: MATLAB天线OpenCVVHDL
pdf
开关电源回路控制设计参考资料
  • 1星
  • 2022-08-01
  • 232.59KB
  • 需要1积分
  • 0次下载
  • favicon收藏
  • rep举报
  • free评论
标签: 电源
电源
开关电源回路控制设计参考资料
张飞实战电子官方½站:www.zhangfeidz.com
☜点击打开
(广告勿扰100%拒绝水贴,10名疯狂工程师运营的½站,有问必答)
Designing Stable Compensation Networks for
Single Phase Voltage Mode Buck Regulators
December 2003
TB417.1
Author: Doug Mattingly
Technical Brief
Assumptions
This Technical Brief makes the following assumptions:
1. The power supply designer has already designed the
power stage of the single phase buck converter. The last
step to the design is the compensation network.
2. The designer has at least a basic understanding of
control systems theory.
3. The designer has a basic understanding of Bode plots.
Output Filter
The output filter consists of the output inductor and all of the
output capacitance. It is important to include the DC
resistance (DCR) of the output inductor and the total
Equivalent Series Resistance (ESR) of the output capacitor
bank. The input to the output filter is the PHASE node and
the output is the regulator output. Figure 3 shows the
equivalent circuit of the output filter and its transfer function.
PHASE
ESR
DCR
OUT
Introduction
Synchronous and non-synchronous buck regulators have
three basic blocks that contribute to the closed loop system.
These blocks consist of the modulator, the output filter, and
the compensation network which closes the loop and
stabilizes the system.
ERROR
AMPLIFIER
REFERENCE
_
MODULATOR
OUTPUT
FILTER
OUTPUT
GAIN
FILTER
1 + s
ES R
C OUT
1 + s
ESR + DCR
+s
OUT
OUT
OUT
FIGURE 3. THE OUTPUT FILTER
COMPENSATION
NETWORK
FIGURE 1. BASIC BLOCKS OF THE BUCK REGULATOR
Modulator
The modulator is shown in Figure 2. The input to the
modulator is the output of the error amplifier, which is used
to compare the output to the reference.
IN
OSC
∆V
OSC
OUTPUT OF
ERROR AMPLIFIER
DRIVER
PWM
COMPARATOR
PHASE
DRIVER
The transfer function for the output filter shows the well
known double pole of an LC filter. It is important to note that
the ESR of the capacitor bank and the DCR of the inductor
both influence the damping of this resonant circuit. It is also
important to notice the single zero that is a function of the
output capacitance and its ESR.
Open Loop System
Figure 4 illustrates the open loop system and presents the
transfer function.
DCR
OUT
E/A
OUTPUT
ESR
FIGURE 2. THE MODULATOR
The output of the modulator is the PHASE node. The gain of
the modulator is simply the input voltage to the regulator,
IN
, divided by the peak-to-peak voltage of the oscillator,
∆V
OSC
, or:
V IN
GAIN MODULATOR
∆V
OSC
s
ESR
IN
OUT
GAINOPENLOOP
∆V
OSC
s
ESR + DCR
s
OUT
OUT
OUT
FIGURE 4. THE OPEN LOOP SYSTEM
The peak to peak voltage of the oscillator can be obtained
from the data sheet for the controller IC.
☜点击打开
CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures.
1-888-INTERSIL or 321-724-7143
Intersil (and design) is a registered trademark of Intersil Americas Inc.
Copyright © Intersil Americas Inc. 2003. All Rights Reserved
All other trademarks mentioned are the property of their respective owners.
☜点击打开
Technical Brief 417
Figure 5 shows the asymptotic Bode plot of the open loop
system gain.
V IN
log
∆V
pp
GAIN (dB)
Figure 7 shows the closed loop system with a Type II
compensation network and presents the closed loop transfer
function.
The following guidelines will help calculate the poles and
zeroes, and from those the component values, for a Type II
network.
1. Choose a value for R
, usually between 2k and 5kΩ.
ESR
LC
-40dB/DEC
-20dB/DEC
FREQUENCY (Hz)
FIGURE 5. OPEN LOOP SYSTEM GAIN
2. Pick a gain (R
/R
) that will shift the Open Loop Gain up
to give the desired bandwidth. This will allow the 0dB
crossover to occur in the frequency range where the
Type II network has a flat gain. The following equation will
calculate an R
that will accomplish this given the system
parameters and a chosen R
F ESR
2 DBW
∆V
OSC
R 2
R 1
V IN
F LC
F ESR
Figure 5 represents a generic open loop system. Specific
systems will have different double pole and ESR zero
frequencies. For systems with very low DCR and ESR
parameters, the phase will experience a very sharp slope
downward at the double pole while the gain will have a
rather high peak at the double pole. Systems that have such
resonant output filters will be more difficult to compensate
since the phase will need an extra boost to provide the
necessary phase margin for stability. Systems such as this
will typically need a Type III compensation, which will be
discussed later in this brief.
3. Calculate C
by placing the zero a decade below the
output filter double pole frequency:
C 2
R 2
F LC
4. Calculate C
by placing the second pole at half the
switching frequency:
C2
C 1
π ⋅
R 2
C 2
F sw
Closing The Loop - The Compensation
Network
Closing the control loop allows the regulator to adjust to load
perturbations or changes in the input voltage which may
adversely affect the output. Proper compensation of the
system will allow for a predictable bandwidth with
unconditional stability. In most cases, a Type II or Type III
compensation network will properly compensate the system.
The ideal Bode plot for the compensated system would be a
gain that rolls off at a slope of -20dB/decade, crossing 0db at
the desired bandwidth and a phase margin greater than 45
o
for all frequencies below the 0dB crossing. For synchronous
and non-synchronous buck converters, the bandwidth
should be between 20 to 30% of the switching frequency.
Figure 8 shows the asymptotic Bode gain plot and the actual
gain and phase equations for the Type II compensated
system. It is recommended that the actual gain and phase
plots be generated through the use of commercially
available analytical software. Some examples of software
that can be used are Mathcad, Maple, and Excel. The
asymptotic plot of the gain and phase does not portray all
the necessary information that is needed to determine
stability and bandwidth.
The compensation gain must be compared to the open loop
gain of the error amplifier. The compensation gain should
not exceed the error amplifier open loop gain because this is
the limiting factor of the compensation. Once the gain and
phase plots are generated and analyzed, the system may
need to be changed somewhat in order adjust the bandwidth
or phase margin. Adjust the location of the pole and/or zero
to modify the profile of the plots.
If the phase margin proves too difficult to correct, then a
Type III system may be needed.
Type II Compensation
Figure 6 shows a generic Type II compensation, its transfer
function and asymptotic Bode plot. The Type II network
helps to shape the profile of the gain with respect to
frequency and also gives a 90
o
boost to the phase. This
boost is necessary to counteract the effects of the resonant
output filter at the double pole.
If the output voltage of the regulator is not the reference
voltage then a voltage programming resistor will be
connected between the inverting input to the error amplifier
and ground. This resistor is used to offset the output voltage
to a level higher than the reference. This resistor, if present,
has no effect on the compensation and can be ignored.
☜点击打开
☜点击打开
Technical Brief 417
s
R 2
C 2
GAIN
TYPEII
s
s
OUT
REFERENCE
COMP
GAIN (dB)
-20dB/DEC
R 1
C 1
C1
C2
log
-20dB/DEC
FREQUENCY (Hz)
FREQUENCY (Hz)
-30
PHASE
90
o
PHASE
“BOOST”
-60
-90
FIGURE 6. GENERIC TYPE II NETWORK
☜点击打开
☜点击打开
Technical Brief 417
IN
OSC
∆V
OSC
PWM
COMPARATOR
DRIVER
PHASE
ESR
DCR
OUT
DRIVER
COMP
REFERENCE
s
s
ESR
IN
OUT
GAIN
SYSTEM
C 1
C 2
∆V
OSC
s
ESR + DCR
s
OUT
OUT
OUT
s
s
R 2
C 1
C 2
FIGURE 7. CLOSED LOOP SYSTEM WITH TYPE II NETWORK
ERROR AMP
DC GAIN
OPEN LOOP
ERROR AMP GAIN
GAIN (dB)
GAIN BANDWIDTH
PRODUCT
0.1F
LC
MODULATOR
& FILTER GAIN
-20dB/DEC
CONVERTER
GAIN
LC
ESR
BANDWIDTH
COMPENSATION
GAIN
0.5 F
SW
FREQUENCY
GAIN dB
f
GAIN MODULATOR
GAIN FILTER
GAIN TYPEII
PHASE
f
PHASE MODULATOR
PHASE FILTER
PHASE TYPEII
V IN
Where:
GAIN
log
MODULATOR
 ∆V
OSC
GAIN FILTER
log 1
2πf
ESR
C OUT
2πf
ESR
DCR
log
2πf
OUT
OUT C OUT
2πf
ESR
DCR
OUT
PHASE FILTER
atan
2πf
ESR
C OUT
atan
2πf
L OUT
C OUT
C1
C2
log
2πf
log 1
2πf
C1
C2
o
PHASE TYPEII
90
atan
2πf
R 2
C 2
atan 2πf
R2
C 1
C 2
GAIN
log 1
2πf
TYPEII
FIGURE 8. TYPE II COMPENSATED NETWORK
☜点击打开
☜点击打开
Technical Brief 417
Type III Compensation
Figure 9 shows a generic Type III compensation, its transfer
function and asymptotic Bode plot. The Type III network
shapes the profile of the gain with respect to frequency in a
similar fashion to the Type II network. The Type III network,
however, utilizes two zeroes to give a phase boost of 180
o
This boost is necessary to counteract the effects of an under
damped resonance of the output filter at the double pole.
Figure 10 shows the closed loop system with a Type III
function.
The guidelines for positioning the poles and zeroes and for
calculating the component values are similar to the
guidelines for the Type II network.
2. Pick a gain (R
/R
Type III network has its second flat gain. The following
equation will calculate an R
given the system parameters and a chosen R
DBW
∆V
OSC
R 2
R 1
F LC
V IN
Figure 11 shows the asymptotic Bode gain plot for the
Type III compensated system and the gain and phase
equations for the compensated system. As with the Type II
compensation network, it is recommended that the actual
gain and phase plots be generated through the use of a
commercially available analytical software package that has
the capability to plot.
phase plots are generated the system may need to be
changed after it is analyzed. Adjust the poles and/or zeroes
in order to shape the gain profile and insure that the phase
margin is greater than 45
o
3. Calculate C
by placing the zero at 50% of the output
π
LC
4. Calculate C
by placing the first pole at the ESR zero
frequency:
π
ESR
5. Set the second pole at half the switching frequency and
also set the second zero at the output filter double pole.
This combination will yield the following component
calculations:
SW
LC
π
SW
☜点击打开
展开预览
推荐帖子 最新更新时间:2022-08-11 04:04
μC/OS-Ⅱ移植到MSP430F149上的步骤
      从μC/OS-Ⅱ的软硬件体系结构可以看到,与处理器相关的代码主要是OS_CPU.H、OS_CPU_A.ASM和OS_CPU_C.C这三个文件,移植的过程也就是对这三个文件的编写。         OS_CPU.H包括了用#define语句定义的、与处理器相关的常数、宏及类型。其中,重点是实现临界段代码保护函数OS_ENTER_CRITICAL()和OS_EXIT_CRITICAL(
Aguilera 微控制器 MCU
请教几个ucos临界段的问题
我刚开始学习ucos,有几个问题不是很明白,ucos中处理临界段代码可以用关中断再开中断的方法:OS_ENTER_CRITICAL()和OS_EXIT_CRITICAL(),也可以给调度器上锁和开锁:Locking and UnLocking the Scheduler,我有两个问题:1.给调度器上锁和开锁不是只能禁止任务调度吗? 如果有中断来时还是会跳去执行中断服务函数啊,这样不就不能起到保护临
我是传奇11 实时操作系统RTOS
用CCS连接XDS100V3调试目标板的一例故障解决
最近用CCS连接XDS100V3调试CC1310时,发现无法连接目标板。 在Verify时报错如下: [Start] Execute the command: %ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
Jacktang 微控制器 MCU
雷达技术正在改变驾驶舱内感应市场的三大趋势
雷达传感器不仅改变了车辆感知周围环境的方式,而且还改变了它们感知物体和乘员的方式。想象一下:有一辆能够检测到后座遗忘儿童或患病驾驶员,并设计了一个系统来采取行动缓解这种情况的汽车。 雷达具有穿透固体材料进行检测的能力,使其能够比以往任何时候都更精确地检测无人看管的儿童、监视乘员状态并预估驾驶员的生命体征。 在本篇技术文章中,随着越来越多的汽车制造商将注意力转向雷达传感器上,我将探讨汽车
alan000345 微控制器 MCU
有直流/直流电源的 ISOW7841 增强型隔离器!你!值得一看!
带有集成电源的效率最高、辐射最低的增强型隔离器―― ISOW7841震撼登场! 凭借业界最高效的功率传输、最低辐射发射和最高抗扰性,ISOW7841 增强型数字隔离器有助于支持工业系统的可靠运行。 在这里你可以: >>下载产品说明书 >>立即订购 >>评估模块 该器件具有 • 集成式隔离电源和高达 100Mbps 的数据传输速率,可最大程度地减少电路板空间并降低成本,从而实现简化
EEWORLD社区 TI技术论坛
在PCB板边走高频高速信号线的注意事项
我们经常在教科书或者原厂的PCB Design Guide里看到一些关于高频高速信号的设计原则,其中就包括在PCB电路板的边缘不要走高速信号线,而对于板载PCB天线的设计来说,又建议天线要尽量靠近板边放置。这是什么科学道理? 我们在初中阶段就已经知道,安培右手定则中导线电流沿着拇指的方向传播,则导线上会产生对应的磁场,磁场的方向与右手手指握拳的方向一致,而导体中的带电电荷会产生电场,电场和磁
okhxyyo PCB设计
评论
登录/注册
意见反馈
求资源
回顶部
查找数据手册?
EEWorld Datasheet 技术支持
热门活动
相关视频
可能感兴趣器件
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
北京市海淀区知春路23号集成电路设计园量子银座1305 电话:(010)82350740 邮编:100191
电子工程世界版权所有 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2022 EEWORLD.com.cn, Inc. All rights reserved
