热搜关键词: 电路基础ADC数字信号处理封装库PLC
pdf
电源完整性设计指导
  • 1星
  • 2022-07-04
  • 908.93KB
  • 需要1积分
  • 5次下载
标签: 电源
电源
电源完整性设计指导电源完整性设计指导
张飞实战电子官方½站:www.zhangfeidz.com
☜点击打开
(广告勿扰100%拒绝水贴,10名疯狂工程师运营的½站,有问必答)
SPECCTRAQuest
电源完整性(PI)设计指导
Product Version 14.2
January 2002
翻译:dyyxh@byhh,ytht
bluemachine@smth
tzyhust@163.com
dyyxh@pcbtech
该文译自
cadence
设计指导
☜点击打开
☜点击打开
1.2
1.3
1.4
简介
......................................................1
面临的挑战:高速
PCB
设计中的电源完整性问题(PI)
解决方法:SPECCTRAQuest
Power Integrity
.............................................................................1
SPECCTRAQuest Power Integrity
工½流程
模块的½用
.........................................................................2
电源平面分析的准备工½
.......................................4
2.1.1
调用设½向导
..............................................................................................................................4
板框
.......................................................................................................................................................5
Stack-up
................................................................................................................................................6
DC Net/Plane Association
................................................................................................................8
DC Power Pair Setup
.........................................................................................................................9
库安装
................................................................................................................................................10
2.6.1
选择一个去耦电容库
2.6.2
选择一个去耦电容
2.6.3
调整一个去耦电容
....................................................................................................................11
2.6.4
内在电感
....................................................................................................................................12
2.6.5
安装电感
....................................................................................................................................13
2.1
½用设½向导
.....................................................................................................................................4
2.2
2.3
2.4
2.6
章 电源完整性设计与分析
.........................................14
3.1
电源平面目标阻抗
..........................................................................................................................14
3.2
单结点仿真
.......................................................................................................................................14
概述
..........................................................................................................................................14
运行单结点仿真
........................................................................................................................15
关于工½表的处理
Working in the worksheet ..........................................................................16
分析
Analysis
....................................................................................................................................16
3.3.1
波½分析
3.4
报告
.....................................................................................................................................................18
3.5
多节点仿真
.......................................................................................................................................19
½格化电源平面
3.5.1
3.5.2
分析属性
..................................................................................................................................20
3.5.3
布½元件
....................................................................................................................................21
3.5.4
放½电压调节模块
VRM ..........................................................................................................21
3.5.5 Placing Noise Sources ................................................................................................................21
3.5.6 Placing Decoupling Capacitors...................................................................................................22
布局前操½
..............................................................................................................................23
3.5.7
3.5.8 Post-Placement Operations .........................................................................................................24
3.5.9 Crossprobing...............................................................................................................................24
3.2.1
3.2.2
3.2.3
临时封装
....................................................25
4.1
概述..................................................................................................................................
建立临时表贴封装..........................................................................................................
4.3 Creating Temporary Leaded Packages............................................................................. 26
章 电压调节模块
VRM ..............................................27
5.1 Working with the Voltage Regulator Module .................................................................. 27
5.2
VRM 编辑器.....................................................................................................................
27
☜点击打开
☜点击打开
简介
本章主要包括以下主题:
1.
挑战:高速PCB设计中的电源完整性问题(PI)
2.
解决方法:
SQ PI
3. SQ PI Workflow
4. Use Models
1.1
面临的挑战:高速PCB设计中的电源完整性问题(PI)
随着时钟和数据信号频率的增高和高速系统的板上组装越来越密,
无噪声的电源分配成为了
PCB设计的一个主要挑战。½快速翻½设备同时改变状态时,通过电源分配系统的纹波噪声随
频率的变化而变化。这个噪声也可以依次干扰高速设备周围的环境。
Important
没有足够的电源支持,高速元件的行为将是不可预测的。
为了确保在各个级别下良½的电源分配,
电源分配阻抗必须在一个很½的频率范围内加以控
制。这可以通过在目标频率范围内仔细的考虑开关电源,大电容,陶瓷电容以及电源-地平面对
等因素来实现。去耦电容在逻辑开关时给需要大电流的驱动器件提供本地电荷源。
图1-1显示了在控制电源分配系统
(PDS)
目标阻抗时各个频率范围内哪种器件是最有效的。
PDS中的元件
注意:电容的½用:
。给最近的主动器件提供本地电压源
。给噪声提供了到地的½阻回路
Tip
电容本身的寄生电感限制了它们的有效频率范围,因而½可以试用表贴电容来减小电感
Figure 1-1
1.2
解决方法:SPECCTRAQuest
Power Integrity
SQ PI帮助½进行对PCB电源分配系统进行设计,建模和分析。SQ PI对电源平面结构(包括连
接过孔)进行建模,综合去耦电容的数量,并分析板内去耦电容½½的物理效应。
1.3
工½流程
高层次的流程由以下步骤组成:
1.
设½板的分析数据库;
☜点击打开
☜点击打开
2.
定义目标阻抗;
3.
进行单结点分析验证并优化电容选择;
4.
进行多节点分析并优化布局。
表1-1 提供了每一阶段的任务细分
Table 1-1
工½流程任务表
任务
可以½用设½向导来逐步的建立电源完整性分析所需
要的板级数据库,本阶段任务有:
■ 创建并导入板框
■ 明确板子的层叠关系
■ 给平面加上DC电压
■ 匹配电源平面对
■ 选择去耦电容
可以通过确定仿真参数来得到目标阻抗,
包括电源平面
电压½迹(rails?)、噪声容限(ripple
tolerance)、最
差动态电流等。得到这些参数以后,
SQ PI
推荐维持目
标阻抗所需的电容个数。本阶段任务有:
■ 选择一个电源平面对分析
■ 确定ripple
tolerance
■ 确定最大delta
current
■ 确定参数for
the voltage regulator module
可以½用单结点仿真来得到维持目标阻抗所需要的电
容选择,
单结点仿真½用来自班上一个节点提取出来的
子电路。去耦电容½被考虑,½他们并没有进行布局。
电源平面分析是在理想情况下进行。本阶段任务包括:
■ 选择一个平面对进行分析
■ 确定a
ripple tolerance
■ 确定一个最大delta
current
■ 确定参数for
Simulating to validate capacitor selection.
通过分析从多节点提取出的子电路可以优化布局时的
电容分配。
SQ PI
在电源平面分析时考虑了电容布局。
本阶段任务有:
■设½分析参数Setting
analysis preferences
■选择平面对分析
■确定
a ripple tolerance
■Specifying
a maximum delta current
■确定参数for
■评估带有噪声源的阻抗impedance
profile
■ 放½去耦电容Placing
decoupling capacitors
Cross probing
Phase
数 据
库 设
½
更多请看
“Preparing for Powerplane Analysis”
“Temporary Packages”
Phase
定义
目标
阻抗
“Powerplane Target Impedance”
“Working in the worksheet”
“Working with the Voltage Regulator
Module”
Phase
单结
点分
“Single-Node Simulation”
Module”
“Running a single-node simulation”
“Analysis”
“Multi-Node Simulation”.
“Gridding
Planes
for
Multi-node
Simulation”
“Analysis Preferences”
“Powerplane Target Impedance”.
Module”
“Analysis”
“Placing Components”
“Crossprobing”
Phase
多 节
点 分
1.4
SPECCTRAQuest Power Integrity模块的½用
在布板过程中,½可以在一下阶段调用SQ
PI模块:
1.Exploration调查阶段?
☜点击打开
☜点击打开
In the
exploration
phase,
板上并没有布½元件,可½连可用的½表½没有,板框、平面层
铺铜、DC½络分配以及pcb层叠关系等等也½没有放½。SQ
PI½用设½向导来指导½建立用于
电源完整性分析的pcb板的必要步骤。
□关于设计向导½用的进一步信息请参见第二障“电源平面分析的准备工½”。
2.设计阶段
在设计阶段,
板上已经元件已经布局½了,
½还没有开始布线。
如果必要的参数已经设½½,
则可以优化布局并继续进行电源完整性设计和分析。
如果有部分参数没有设½,
则设½向导会自
动弹出来以便½确定缺少的设½信息。
关于电源完整性设计和分析对话框的½用请参见第三章“电源完整性设计和分析”
3.验证阶段
在验证阶段,板子元件已经布局完毕,并且布线也已经完成。这个阶段,½可以通过电源完
整性分析优化布局。
☜点击打开
展开预览
猜您喜欢
评论
登录/注册
意见反馈
求资源
回顶部
推荐内容
热门活动
随便看看
  • 咏茶一体诗
    [b][font=宋体][size=14pt]咏茶一体诗[/size][/font][/b][font=宋体][/font][font=宋体]元稹(唐)[/font][font=宋体][/font][font=宋体]茶。[/font][font=宋体]香叶,嫩芽。[/font][font=宋体]慕诗客,爱僧家。[/font][font=宋体]碾雕白玉,罗织红纱。[/font][font=宋体]铫煎
  • 怎么获取当前PWM状态?
    是高电平还是低电平?STM32F030系列的
  • 电流的大小会损坏元件吗?
    12V 或 5V 的电压电流是 20A ,如果接到 12V 1.5A 或 5V 1.5A 的设备上会损坏这个设备吗?
  • 有的时候真的挺累
    最近一段时间有点忙,其实忙起来学点东西挺开心,可是有的时候会感觉体力不支,没法思考,这种感觉很难受。进展顺利的时候会觉得精力充沛,就算忙到晚上十一点多依旧像打了鸡血一样,心情也是极好的。可是有些时候,觉得好累,什么都不想干,脑袋也转不动,然后就开始重新审视自己到底适不适合这一行。就这样从精神亢奋到失落,循环往复,,,,,亦或许,我真的不该带那么多情绪到工作上。不管怎样,加油! 梦想还是要有的,万一
  • LPC810呼吸灯,闪亮的抛砖了。。
    感谢eeword的送的LPC810开发板。不知道怎么下载?look,用我们的MSP430 launchpad 作为下载器吧!
  • 新手学画板子求助
  • 不太懂单片机能学ARM吗?
  • wifi产品射频电路的一些考虑
  • 你如何定义射频?
  • 去各位救急!!!
