热搜关键词: 电路基础ADC数字信号处理封装库PLC
pdf
fpga 状态机设计
  • 1星
  • 2021-04-04
  • 123.94KB
  • 需要1积分
  • 5次下载
标签: fpga
fpga
fpga  状态机设计
Applications Note:
Predicting the Output of Finite State Machines.
Introduction
The design of finite state machines is a key application of the HDL Designer Series™ tools. Just as it is possible
for a designer to write VHDL that results in poorly performing state machines, it is possible to use HDL Designer
Series™ tools to generate VHDL that results in poorly performing state machines. A key component for the
successful application of a HDL design tool is the users’ confidence that the tool can be used to generate
predictable, high-performance, finite state machine, HDL code.
This applications note explains how elements of the HDL Designer Series™ state diagram editor greatly impact
the resulting HDL code.
The examples in this applications note apply to VHDL. The concepts are equally applicable to designing with the
Verilog™ hardware description language.
This applications note covers the following topics:
Simple “Moore” machines
Simple “Mealy” machines with registered outputs
Simple “Mealy” machines with clocked outputs
The difference between
REGISTERED
and
CLOCKED
output
Signals Status.
Explicitly encoded “Moore” machines
Duplicate states in explicitly encoded “Moore” machines
Some tradeoffs between alternative state machine implementations
Finite state machines using the truth table spreadsheet editor
Page 1 of 23
Revision 2.1
8-Jan-2002
© Mentor Graphics, 1986-2002
Applications Note:
Simple “Moore” Machines
The following is an example of a simple “Moore” machine captured using HDL Designer Series™ tools:
Package List
ieee std_logic_1164
ieee numeric_std
Global Actions
b = '1'
s0
b = '1'
a = '1'
Signals Status
SIGNAL SCOPE DEFAULT
x
OUT
'0'
y
OUT
'0'
Declarations
RESET
STATUS
COMB
COMB
s2
y <= '1';
a = '1'
s1
x <= '1';
Concurrent Statements
Process Declarations
State Register Block
Generated VHDL code for this finite state machine is on the next page.
The implementation of this “Moore” state machine could be represented as follows:
current_state
nextstate
a
b
next_state
clocked
output
x
y
clk
rst
The inputs
a
and
b
are combined with the
current_state
to determine the
next_state.
The value of the
current_state is decoded to produce the outputs
x
and
y.
This structure is generated because:
1.
2.
The output actions (the assignments of
x
and
y)
are associated with a state, not a transition.
The
Signals Status
declares
x
and
y
as
COMBINATORIAL
outputs.
Page 2 of 23
Revision 2.1
8-Jan-2002
Applications Note:
1.
x
and
y)
are only explicitly assigned with their “interesting”
values. Wherever the values of
x
and
y
would otherwise be assigned ‘0’, this is accomplished by
using the
DEFAULT VALUES
in the
Signal Status.
Review the “output” process, (line 62) in the
VHDL code and the interaction between the global action and the explicit state action will be
apparent.
Using
DEFAULT VALUES
(or
GLOBAL ACTIONS
for more complex common actions) ensure
the signals are always assigned on every clock edge, thus avoiding the creation of unwanted
latches during synthesis.
The
RESET
values in the
Signals Status
are empty since the outputs are combinatorial.
2.
3.
VHDL for the “Moore” Machine Example
The VHDL code for the state machine on the previous page follows. (This code has been formatted to compact it
slightly.)
01
02
03
04
05
06
07
08
09
22
23
24
27
28
29
32
33
34
-- VHDL Architecture Sandbox.appsnote_fsm.fsm
-- Generated by Mentor Graphics' HDL Designer(TM)
LIBRARY
ieee ;
USE
ieee.std_logic_1164.all;
USE
ieee.numeric_std.all;
ARCHITECTURE
fsm_moore
OF
appsnote_fsm
IS
-- Architecture Declarations
TYPE
state_type
IS
( s0, s1, s2 );
-- State vector declaration
ATTRIBUTE
state_vector : string;
ATTRIBUTE
state_vector
OF
fsm : architecture
IS
"current_state" ;
-- Declare current and next state signals
SIGNAL
current_state, next_state : state_type ;
BEGIN
clocked :
PROCESS
( clk, rst )
BEGIN
IF
(rst = '1')
THEN
current_state <= s0;
-- Reset Values
ELSIF
(clk'EVENT
AND
clk = '1')
THEN
current_state <= next_state;
-- Default Assignment To Internals
END IF;
END PROCESS
clocked;
-- continued on the following page.
Page 3 of 23
Revision 2.1
8-Jan-2002
Applications Note:
37
38
39
42
43
44
45
46
47
48
49
52
53
54
55
56
57
58
59
62
63
64
65
66
67
68
69
72
73
74
75
76
77
78
79
nextstate :
PROCESS
( a, b, current_state )
BEGIN
CASE
current_state
IS
WHEN
s0 =>
IF
(a = '1')
THEN
next_state <= s1;
ELSIF
(b = '1')
THEN
next_state <= s2;
ELSE
next_state <= s0;
END IF;
WHEN
s1 =>
IF
(a = '1')
THEN
next_state <= s2;
ELSIF
(b = '1')
THEN
next_state <= s0;
ELSE
next_state <= s1;
END IF;
WHEN
s2 =>
next_state <= s0;
WHEN OTHERS
=> next_state <= s0;
END CASE;
END PROCESS
nextstate;
output :
PROCESS
( current_state )
BEGIN
x <= '0';
y <= '0';
-- State Actions
CASE
current_state
IS
WHEN
s1 =>
x <= '1';
WHEN
s2 =>
y <= '1';
WHEN OTHERS
NULL;
END CASE;
END PROCESS
output;
-- Concurrent Statements
END
fsm_moore;
1.
2.
There are three processes: “clocked”, “nextstate” and “output”.
In the “output” process, the
DEFAULT VALUES
(line 65) define the output values, except where
overridden by the explicit assignments associated with states (line 72).
Page 4 of 23
Revision 2.1
8-Jan-2002
Applications Note:
“Moore” Machine Post Synthesis Timing Behavior
The performance of the “Moore” machine after synthesis is as follows:
a/b
clk
next_state
current_state
x/y
clocked
output
nextstate
The delay on the outputs
x
and
y
is (t
clocked
+ t
output
) and the outputs
x
and
y
may glitch. They are
synchronous and will be stable before the next rising edge of the clock –
assuming that (t
clocked
+ t
output
+ t
setup
) < the clock period.
Page 5 of 23
Revision 2.1
8-Jan-2002
展开预览
猜您喜欢
评论
登录/注册
意见反馈
求资源
回顶部
推荐内容
热门活动
随便看看
  • 希望官方组织团购eZ430-Chronos
    关于价格我的查询:官方上面是$49,mouser上面是350人民币,说了半天最后告诉我美国限制出口。(不是广告,打电话给n个机构大家都说不行,要么要我买10块以上)淘宝上能从外国购买的说不能通过审批,付款半月后给我退了。建议eeworld组织团购一次1.先问问是否可行,因为这个美国限制出口2.有这次拍卖的人气,这次拍卖凡是出价的押金都不退,或者都如实公布拍卖纪录,以这些人为基础进行团购支持的顶我
  • USB_M8_RGBLED彩灯
    用M8控制RGBLED测试了一下,效果不错。并做了一个上位机软件,通过USB控制,现将资料整理上传与君共享!源码资料包[url=http://www.ouravr.com/bbs/bbs_upload88916/files_9/ourdev_196735.rar][color=#0000ff]点击此处下载ourdev_196735.rar(文件大小:1.52M)[/color][/url]原理图(
  • 怎样与小区监控摄像头连接
    请高手帮忙我小区有很多摄像头我电脑怎样能连接小区摄像头?也可以发我邮箱里谢谢![email]nangongdongjing@21cn.com[/email]
  • wince+s3c2440充电指示的问题
    目前我做一款手持机,需要关机充电的时候给个充电指示,像手机一样,这样就必须打开2440和LCD,当然wince可以不用启动,我用USB充电,就是说最大充电电流只有500mA,这样就有一个问题,充电电流大部分被2440和LCD消耗了,问下各位是如何解决的这个问题??
  • 钽电容极性
    SMD钽电容跟一般元件的正负标示是反著的,贴片钽电容有标记的一端是正极,另外一端是负极;引线钽长腿的正极,钽电容不能接反,接反后就不起作用了。
  • 【删繁就简 】 八分法画圆
  • LPC1300 的示例代码, 有个写法看不明白?求大虾指点
  • FPGA设计需要的技能
  • TI Cortex M3串口转以太网例程概述
  • TLP3547评测之(二)
